keyless entry, horn, trunk pull down ... - Chevy Impala SS Forum
post #1 of 18 (permalink) Old 08-27-2016, 01:53 AM Thread Starter
V8killer's Avatar
1995 fleetwood:
-shorting the reprogramming wire hanging in the trunk does not cycle the locks (2 pin male connector). key fob does not work (has new battery) obviously. car had been sitting for a few years before i bought it back. i thought i might have to reprogram the fob so when i shorted the wire to put it into programming mode, the locks did not cycle.
-Horn does not work
-trunk pull down does not engage, checked and it's getting power
fuses for all 3 of these problems are good.
does anything jump at you guys that might be a main problem causing all 3? or do i have 3 separate issues that need to be hunted down?
Thanks.
STOLEN ON JUNE 8TH OR 9TH 2003 FROM TACOMA,WA
ISSF MEMBER #282
94 9C1,SS clone,DCM,SSRI,HA/F-body sway bars,3.42's Bonnies,floorshift,Stillen front,Smoothy rears,billet grille,white face Z-28 dash, Dynomax mufflers,Tri-Y,eibach,J&M control arms,NOS 100 shot,MSD digital+6&coil,MSD super conductors,metco safety loop,Dynotech driveshaft [email protected]
V8killer is offline
post #2 of 18 (permalink) Old 08-27-2016, 03:10 AM
I'm not at my FSM now, but you mmay just have 3 things coincidentally fubared at once, and check into Fleetwood's CCM if it happens to control those items.
EDIT: Woah! That was eerie. This popped up first googling Cadillac Fleetwood CCM. We might be onto something:
http://www.cadillacforums.com/forums...ol-module.html
96 Black is online now
post #3 of 18 (permalink) Old 08-27-2016, 05:27 PM Thread Starter
V8killer's Avatar
I read that thread too. Gonna check the black box they're referring to since everything else is working fine. Locks, seats, trunk popper etc etc. thanks.
ISSF MEMBER #282
V8killer is offline
post #4 of 18 (permalink) Old 08-27-2016, 05:51 PM Thread Starter
V8killer's Avatar
Pulled the CCM codes:
44
131
144
44 is steering wheel sensor shorted which might explain the horn.
Don't know what the other 2 are.
ISSF MEMBER #282
V8killer is offline
post #5 of 18 (permalink) Old 08-27-2016, 09:12 PM
ocala's Avatar
I'm not SURE, but I read somewhere that the 1 in front of the "31" or "44" means the the code has occurred before. This would apply to any code. So 117 would mean that you had a prior code 17 still in the computer.
So you would have had 44 twice, and 31 once. Not sure if this is correct, but I read it somewhere...
It would make sense since all the codes only go up to 99, and start at 11. Two digits only...
http://www.troublecodes.net/gm/95_57p/
Hope this helps.
ocala is offline
post #6 of 18 (permalink) Old 08-27-2016, 09:14 PM
ocala's Avatar
Sorry, 44 TWICE
31 once
ocala is offline
post #7 of 18 (permalink) Old 08-27-2016, 09:31 PM
Shilaeli Hugger's Avatar
Stupid question but did all the B cars honk the horn with the factory keyless when u lock it?
96 BBB 9c1. Rebuilt out of lets just say north of 30 cars.
94 MGR L99. Met a bridge.
92 White L03. Ran to death.
94 OSP 9C1. Lawn ornament.
91 Silver L03. Whales on ice is sad.
94 Black 9c1 clone. Sacrificed.
92 DCM to flat black L03 RMW. Blowed up... twice.
96 Black Woody RMW. Cannibalized.
92 Grey RMS L05. New daily driver.
"i built it one piece at a time, and it didn't cost me a dime!" Johnny Cash
Shilaeli Hugger is offline
post #8 of 18 (permalink) Old 08-27-2016, 09:35 PM
GM 94 5.7L VIN P ? OBD/OBD2 Trouble Codes
GM 95 5.7L VIN P ? OBD/OBD2 Trouble Codes
GM 96 5.7L VIN P ? OBD/OBD2 Trouble Codes
post #9 of 18 (permalink) Old 08-27-2016, 09:38 PM
ocala's Avatar
I listed the PCM codes and not the CCM codes, but I think the above would still apply.
ocala is offline
post #10 of 18 (permalink) Old 08-27-2016, 09:45 PM
ocala's Avatar
My Roadmaster doesn't. It's been so long since I drove the Impala I can't remember...
ocala is offline
