#17 fuse is burning when ignition key to turn on - Chevy Impala SS Forum
 1Likes
post #1 of 21 (permalink) Old 10-09-2016, 12:50 PM Thread Starter
1992 caprice classic
I have a troble with #17 fuse. It's burning when ignition key turn to on (one time turn clockwize) but not start a car.
I disconnected:
1. radio
2. left hand twilight sentinel block
3. TCC black conntctor on brake pedal
4. instrument panel dash
5. climate control module with fluid warning cener
6. audio alarm module
7. fuel conector from the rear of the car(fuel tank).
Does not work and shows:
- fuel gauage on instrument panel - cannot see coz its in deep space!
- coolant gauage - more than max
- all lamps on fluid warning cener and instrument panel does not blink and not work when ignition switched/turned to "on"
- speedometr - works.
When ignition is "on" - 17 fuse burn.
Any body can help me as possible?
VladimirSh is online now
post #2 of 21 (permalink) Old 10-09-2016, 06:27 PM
The #17 fuse is hot in start, bulb check, and run. It uses a pink and black wire. It goes to the diagnostic reserve module, torque converter clutch/cruise release switch, twilight sentinel, audio alarm module, electronic compass, rear defogger relay timer, fluid warning center, low coolant module, instrument cluster, height sensor, and headlight switch illumination lamp. If you unhook all of them, and start plugging them back in one by one, when you get to the erroneous one, it will blow the fuse.
atlantadan likes this.
post #3 of 21 (permalink) Old 10-10-2016, 04:54 AM Thread Starter
Does it possible to show connectors/components it on pictures?
post #4 of 21 (permalink) Old 10-10-2016, 05:14 AM Thread Starter
Can you show in pictures?
post #5 of 21 (permalink) Old 10-10-2016, 07:31 AM
I would have to copy numerous pages from the FSM. All of them have a pink and black wire coming from the fuse block. There are a couple of splices as well. Most of the modules can be found relatively easily. The only one that is obscure is the diagnostic energy reserve module and it is found on the driver's side of the steering column along the top underside of the dash support.
post #6 of 21 (permalink) Old 10-10-2016, 07:35 AM
Banned
being this old my guess is a shorted wire. this is not from a component IMO.
the under dash wiring does short out on the sharp machined metal edges.
look for wires that have NO LOOM coverings and wires that have been screwed with by wire hacker. ALARM TECH'S ETC..
on my 96 Impala I had a wire short out on the sharp metal in the driver door..
the had to use a magnifying glass to reveal the short it was so small. I then just taped up all the wiring in the door and I also went through the rest of the vehicle and used the tape/plastic loom to prevent any future wiring shorts..
j cat is offline
post #7 of 21 (permalink) Old 10-10-2016, 07:57 AM
The wire short sounds like the ticket. You are going to be doing a lot of chasing. Look for burn marks on the metal as well as cuts in the wire wrap/tape.
post #8 of 21 (permalink) Old 10-12-2016, 03:33 PM Thread Starter
I disconnected black connector c203. Fuel and temp gauges low down.
post #9 of 21 (permalink) Old 10-14-2016, 11:05 AM Thread Starter
Where is connectors:
ckt30
c400
c402
post #10 of 21 (permalink) Old 10-14-2016, 03:20 PM
Banned
ckt30
c400
c402
C400 is in the trunk driver side. C402 should be the one behind the rear license plate.
check all those driver side connectors because for some reason these get hacked/damaged.. also check that the trunk grounds are solid.
CKT30 not sure will have to open the GM repair manual.
j cat is offline
