Does your alternator plug have...? - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 10-29-2016, 06:12 PM Thread Starter
a rubber sleeve around the end like most "Weather Pack' connectors?
I recalled it having a orangish/red ribbed sleeve
the pic is the connector without the sealing rubber sleeve
post #2 of 9 (permalink) Old 10-29-2016, 07:21 PM
Mine - original - looks just like the pic. Interesting that the hood light - a much less critical fastener, has a weatherpac.
I wouldn't worry - it's a good tight seal.
grandpas wagon
grandpas wagon is offline
post #3 of 9 (permalink) Old 10-29-2016, 08:32 PM
Weatherpack seals are standard for under the hood. I think all connectors are weatherpack, even the O2 sensors. Check the antenna, washer fluid pumps, and evap canister.
post #4 of 9 (permalink) Old 10-30-2016, 11:07 AM Thread Starter
My connector is original. The pic was just from the web I found. I did a search for the plug to see if a replacement would come with the rubber sleeve but none I saw had one so I was asking if anyone's "original" had one.
I thought mine originally came with a rubber sleeve like the weather pack connectors have but if fell off at some point (engine swap??)
It just looks like there is a gap when plugged in that would be filled with the compressed rubber sleeve (like weather pack connectors have)
I have replaced weather pack connectors themselves before and have the tools to do that.
Can't seem to find a source for just parts other than "kits" with various sizes of male/female pins and the small round rubber parts that slide over each wire but can't find just the rubber sleeves in the various sizes for weather pack aka GM/Delphi type connectors
post #5 of 9 (permalink) Old 10-30-2016, 12:42 PM
The connector is supposed to have one. I am headed to the yard this week. I will check for one.
post #6 of 9 (permalink) Old 10-30-2016, 02:28 PM Thread Starter
LMK Fred. Would be happy to take one off your hands if you come across one
post #7 of 9 (permalink) Old 11-25-2016, 12:14 AM
95wagon's Avatar
A little late to the party,
My original 1995 "B" alternator plug only has that "face seal" like the picture you linked.
I am 99% sure the plug type , with it's irregular squared corners do not have a seal like weather pac or metri pac
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #8 of 9 (permalink) Old 11-25-2016, 03:20 AM
That blue grommet looked designed to make a pretty good seal on its own. Sure enough just checked and mine (at least my SS) has no other accordion-type seal.
post #9 of 9 (permalink) Old 11-25-2016, 03:45 PM Thread Starter
yes after getting a few of the rubber accordion seals from Fred...they don't go on that plug.
