Engine temp sensor connector? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 01-02-2017, 08:28 PM Thread Starter
FUN 9C1's Avatar
Does anyone have a source for a new connector "pigtail" for the engine temp sensor (the sensor between #6 and 8 plugs)?
If not, is there any reason I could not just use an aftermarket connector to one of the pins on the sensor? From looking at the old pigtail, it looks like the middle pin is just a guide as the hole in the pigtail is just plastic. However, it also looks like, from using my multilmeter, that the two pins are connected inside the sensor since I get no resistance between the two pins. So I wouldn't think it would matter which pin I connect to.
Thanks for any help or clarification.
'96 BBB
'95 9C1, "Ol' Statey", ex Maine state police, programming, 4.10s, 2 1/2" exh, cut 9c1 front springs, stock SS rear springs.
'96 RMW, parts car
'94 RMW stock for now... new daily driver
'95 FWB V4P, driven for fun and for towing
'13 Dodge Charger Hemi AWD R/T Plus, wife's daily driver. I get the carbon out of it when I can.
'89 F250 Yard truck. My V8 wheelbarrow..
'86 Correct Craft Ski Nautique, 351 w/ GT40-P heads
'50 Century Imperial Sportsman, all original
FUN 9C1 is offline
post #2 of 3 (permalink) Old 01-02-2017, 09:29 PM
Chain Auto part stores have various pigtails. BWD is a common supplier. Its, IIRC,1 wire
Check rockauto.com
1996 CHEVROLET IMPALA 5.7L V8 Temperature Sender / Sensor Connector | RockAuto
or
http://shop.advanceautoparts.com/p/d...40/22148690-P#
BALLSS is online now
post #3 of 3 (permalink) Old 01-03-2017, 06:18 AM
These guys should have most pigtails you would need....
Automotive Electrical Connector Pigtails, Terminals, Tools and More
If not, then maybe a donor car and you cut the pigtail off from it.
