Bad key or ignition? - Chevy Impala SS Forum
post #1 of 21 (permalink) Old 02-02-2017, 06:28 PM Thread Starter
95DoubleBubble's Avatar
I bought my 94 fleetwood in August 2015, that october I bought and installed a vats bypass from ebay. Lately when I go to start the car it acts like it tripped the vats system but the light doesn't stay on like it did befor the bypass. Usually takes a few times of removing and inserting the key before it will fire ul.
95DoubleBubble is offline
post #2 of 21 (permalink) Old 02-03-2017, 04:05 PM
Just spitballing here, but you may want to bypass your bypass. Maybe there is an issue with how it was installed or something not working right with it. Why did you bypass it in the first place? Was it due to similar issues and maybe that issue is still present? Again, just some wild guesses.....
post #3 of 21 (permalink) Old 02-03-2017, 04:11 PM Thread Starter
the same reason I assumed everyone else does it, it started to do the problem where you start the car and the system woul trip and make you wait to start. I bought one of those pre-assembled bypass kits off eBay that you just plug directly into harness for the vats
post #4 of 21 (permalink) Old 02-03-2017, 08:52 PM
Jimpala95's Avatar
Now that you by-passed the VATS,if you can put the key into the lock cylinder and it turns then it's not a key or lock cylinder issue.Sounds like the VATS module and or VATS relay may be acting up.More so the relay than the module imo.
Jim
Jimpala95 is offline
post #5 of 21 (permalink) Old 02-03-2017, 08:55 PM Thread Starter
Jim
How would I go about fixing that? I have discovered that 75% of the time if I turn the key to the on position and wait five seconds to crank it will usually start.
post #6 of 21 (permalink) Old 02-03-2017, 08:56 PM
Jimpala95's Avatar
Phil,
In re-reading over your original post,almost sounds like it could be another unrelated to the VATS issue? Especially since you say the light does not come on now when you're having the starting issue.
Jim
post #7 of 21 (permalink) Old 02-03-2017, 09:26 PM Thread Starter
Could it have anything to do with the neutral safety switch? My column is old and the shifter does have some play to it, sometimes if I jiggle it around it will start
post #8 of 21 (permalink) Old 02-03-2017, 10:02 PM
TGO
I just went through this last week.
My pass key light was blinking though.
If you want to bypass the vats module completely see his post I made in the pass key/vats thread:
https://www.impalassforum.com/vBullet...5-post210.html
It was a bit of an after thought so that's the best how to I could make.
IDK what kind of module you got off ebay. Do you have a link? Seems most of them are just the resistor trick...it's not a vats bypass it's just a key bypass. The vats module still controls whether or not the car will start...all you're doing is making it think the key is inserted. Apparently the modules like to fail as I found out recently.
NSS could be the culprit as well and so could the ignition switch or the wires leading to it. Apparently those are also a common point of failure. I would think more common than NSS.
TGO is offline
post #9 of 21 (permalink) Old 02-03-2017, 10:14 PM Thread Starter
This is the one I used
Vehicle Anti Theft System Vats Bypass Keycode 2 | eBay
I just saw this one, is it the same thing just more money?
Fortin - PASSLOCK-SL2-V2 - GM Passlock And VATS Transponder Key Bypass Module
post #10 of 21 (permalink) Old 02-03-2017, 11:18 PM Thread Starter
I am now kicking myself in the ass for not thking to ask to disable the vats system when I bought my new ecm last week.
