weird turn signal problem - Chevy Impala SS Forum
 1Likes
post #1 of 22 (permalink) Old 03-31-2017, 08:50 PM Thread Starter
When i use my turn signals the front left and right blink fine but both the tail lights blink instead of just one side. Anyone have any ideas what this might be? bulb? signal switch?
jay96impala is offline
post #2 of 22 (permalink) Old 04-01-2017, 04:20 AM
You probably have a short either in the turn signal switch, or the wiring to the lights. You need a VOM to check the circuits. I would suspect the turn signal switch as my first pick.
post #3 of 22 (permalink) Old 04-01-2017, 10:40 AM
Banned
check the rear lamps/wiring / sockets. use dielectric grease on the lamp sockets .
j cat is offline
post #4 of 22 (permalink) Old 04-01-2017, 12:16 PM
Using dielectric grease will not fix a short. It is not a bad idea to use it, but it has nothing to do with the symptom.
post #5 of 22 (permalink) Old 04-01-2017, 01:02 PM
Banned
correct will not fix short but when you put bulbs back in then you add some of this dielectric grease to prevent bad connections as it can happen with moisture in there.
j cat is offline
post #6 of 22 (permalink) Old 04-01-2017, 01:33 PM
Dielectric grease is most likely ok but prefer to use Bulb Grease for Socketed Bulbs....
bulb grease - Bing images
post #7 of 22 (permalink) Old 04-01-2017, 07:28 PM
91ss's Avatar
A bad bulb can cause that problem. Sometimes when the filament breaks, it shorts across the other filament that is on the common circuit for the parking lights.
j cat likes this.
91ss is offline
post #8 of 22 (permalink) Old 04-02-2017, 01:25 PM Thread Starter
thanks for the replies, when you say in the turn signal switch do you mean this part that pulls out? or the part/mechanism actually inside the column?
post #9 of 22 (permalink) Old 04-02-2017, 02:06 PM
gbhs72's Avatar
Since we don't know what you're driving here is the one for the Caprice/Impala and I think the Buick too. 1993 CHEVROLET CAPRICE 5.7L V8 Dimmer Switch | RockAuto
If you have a Fleetwood then this one, I believe it's Flash to Pass, would be the one. 1994 CADILLAC FLEETWOOD 5.7L V8 Dimmer Switch | RockAuto
If you order from RA don't forget your discount.
Mark: Snowman-33
gbhs72 is offline
post #10 of 22 (permalink) Old 04-02-2017, 02:21 PM Thread Starter
sorry, 96 impala
