After market keyless entry - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 05-05-2017, 03:05 PM Thread Starter
Impalachevy's Avatar
Hi everyone,
I just finished hooking up a Chinese keyless entry for my 1995 Caprice. I wanted to run the locks and trunk release and hook up the indicators to flash when locking/unlocking the car(no horn), the unit came with two brown wires which is a + trigger for indicators. I'm assuming each for a side. The instructions are not clear, where do I connect these? I tried to tap into the hazards fuse but it didn't work. I looked at the fuses(the one in the dash-left side) diagram but couldn't figure if there is two separate fuses for the turn signals.
I thought of running a wire to each indicator in the front, but that seems a bit unsafe and a lot of work.
BTW, the lock/unlock and trunk release works flawless.
I know i'm a little late to the party but if anyone could help it would be truly appreciated. Thanks.
Impalachevy is offline
post #2 of 2 (permalink) Old 05-09-2017, 08:13 PM
KOZ
Headlight switch - Brown wire + parklights
KOZ is offline
