green box under steering wheel - Chevy Impala SS Forum
 1Likes
post #1 of 12 (permalink) Old 07-08-2017, 11:19 AM Thread Starter
Dutchess B Body's Avatar
Question green box under steering wheel
I have had an ongoing issue with my interior lights staying on. The way the lights are supposed to work are when a door is open they turn on, and after a couple minutes they turn off. And when the vehicle is running the lights go out immediately after a door is shut. But the lights are staying on and not going off. My mechanic said it was something with visors and he fixed it and it was all good for about 5 seconds. Anyway I was told on this forum that there is a green box under steering wheel that if it is removed and cleaned that everything should possibly work as it is supposed to. I looked under steering wheel in footwell area and do not see any green box. If someone could post a pic or better guide me that would be awesome. Another thing what would be a good cleaner to buy at auto parts store or hardware store for cleaning it after removal.
Dutchess B Body is offline
post #2 of 12 (permalink) Old 07-08-2017, 08:40 PM
It could be your twilight sentinel as well. They are known for malfunctioning.
post #3 of 12 (permalink) Old 07-09-2017, 04:56 AM
it would be more behind the e brake pedal. you will see the 2 flashers and above that is where the green box lives
Nor*Cal INC - San Francisco, California
1996 Impala SS
1996 Caprice 9C1 6 Speed /4.56s
1995 Caprice 9C1 6 Speed /4.10s
eze415 is offline
post #4 of 12 (permalink) Old 07-09-2017, 08:22 AM Thread Starter
twilight sentinels are on auto headlight vehicles aren't they?, I don't have auto headlights.
post #5 of 12 (permalink) Old 07-09-2017, 08:24 AM Thread Starter
Thanks i'll look there. Do you know of something good for cleaning the box to get it working again.
post #6 of 12 (permalink) Old 07-09-2017, 08:39 AM
juniorwatson's Avatar
I've never had that 'convenience center' box apart before but good old isopropyl alcohol would be my first recommendation on any electrical components.
juniorwatson is offline
post #7 of 12 (permalink) Old 07-09-2017, 11:32 AM Thread Starter
When using isopropyl alcohol should I dilute it or use full strength?. Also should I wipe it with alcohol or pour it over box and dry it. Would like to know good cleaning procedure
post #8 of 12 (permalink) Old 07-09-2017, 12:56 PM
Just a thought, not sure if this is exactly the symptom you have but a few days after I had washed the door openings on my Impala with a lot of water the interior lights suddenly came on and would not turn off, so I had to remove the fuse to be able to park the car overnight. Found out the other day that there was water in the right front door jamb switch which caused the problem. Cleaned the door jamb switch with highpressure air and some CRC 5-56 (WD40). In my case it was an easy fix ;-)
Name:	door jamb switch.jpg
eze415 likes this.
Tony L
1996 Impala SS, black, K&N-filter, Flowmaster 17119, Bilstein Sport Shocks 1104/0929, MSD Spark Wires
1965 Corvette Convertible, white, 327-300 4-speed, Borgeson Power Steering
1987 Astro LT, blue
2008 Prius Executive
2011 Prius Executive,
Solar Powered Ventilation
TonySS is offline
post #9 of 12 (permalink) Old 07-09-2017, 03:25 PM
I would go buy a spray can of "electrical" cleaner. Radio Shack has it
BALLSS is online now
post #10 of 12 (permalink) Old 07-09-2017, 05:58 PM
gbhs72's Avatar
I keep both of these on hand. Different uses but both handy. This one for electronic parts. CRC Electronic cleaner 05703 - Read Reviews on CRC #05703
This one for starters and alternators. CRC Electric parts cleaner 05718 - Read Reviews on CRC #05718
Mark: Snowman-33
gbhs72 is offline
