Windshield washer pump - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 08-26-2017, 09:24 AM Thread Starter
Seems the pump is ok, no power at the connector. I moved recently and not sure where my manuals are.
Can someone give me some info about the connector on the back of the motor?
I search and found a post but image link were dead. Thanks photobucket...
JackFish is offline
post #2 of 11 (permalink) Old 08-27-2017, 11:01 AM Thread Starter
Found this circuit diagram but I'm not electronically inclined>
http://www.goldsswagon.com/diagrams/impala_wipers.pdf
JackFish is offline
post #3 of 11 (permalink) Old 08-27-2017, 01:13 PM
the problem may be more in the column switch
post #4 of 11 (permalink) Old 08-27-2017, 01:46 PM Thread Starter
So if I connect the gray wire from the column in the diagram to ground using the multimeter I should get some voltage when I activate the pump, right?
JackFish is offline
post #5 of 11 (permalink) Old 08-27-2017, 04:34 PM Thread Starter
Well I tried both the grey and pink wires, pink one was dead and the grey one had 2v.
So I'll try swapping out the switch. I can pull one off my parts car but I'm not sure how to remove it without the manual.
JackFish is offline
post #6 of 11 (permalink) Old 08-27-2017, 05:17 PM
IDK which wire does what...but the switch activates the pump. My assumption is the switch is bad.
You can run test wire leads to the pump itself from battery to activate it to confirm the pump works
...and I assume you checked the fuse
I have just read that the column lever/switch can FU (lights, washer,, wipers) so suggested checking that
post #7 of 11 (permalink) Old 08-27-2017, 05:23 PM Thread Starter
I'm hoping it's just the lever so I'll swap that out first.
That just pulls straight out, right?
JackFish is offline
post #8 of 11 (permalink) Old 08-27-2017, 06:44 PM
IDK, never taken one off a B-body
post #9 of 11 (permalink) Old 08-28-2017, 07:40 AM
The switch is probably in the column, not in the turn signal stalk. There may also be a circuit through the wiper motor module. When you use the washer, the wiper activates for 3 cycles.
post #10 of 11 (permalink) Old 08-28-2017, 08:36 AM Thread Starter
Yah might have to go into the column but the turn signal springs are busted too so I can do that as well.
JackFish is offline
