Key In Ignition Beeper? - Chevy Impala SS Forum
 2Likes
post #1 of 14 (permalink) Old 09-16-2017, 07:28 PM Thread Starter
This is a slightly unusual question - I have a friend that for some unknown reason really likes the B/D body "key in ignition" beeper or annunciator and wants to port it back to an older car. There are several potential junkyard donors it could be harvested from. Is this a separately removable part or does it require the late cars' computers to work?
For that matter, where *is* the thing? And what does GM actually call it? Thanks.
Working on a 1994 Cadillac Fleetwood Brougham...
CB700S is offline
post #2 of 14 (permalink) Old 09-16-2017, 11:29 PM
schlicky13's Avatar
My first guess is going to be that GM refers to it as a "chime", seems I've seen that word in the past when referencing things like that, and most of my experience would be with GM. My second guess is that it's going to be under the dash somewhere, driver side and is probably just wired into a circuit that closes while the key is in the ignition and any door is opened. Aside from the resistor pellet in the key themselves, the ignition was still pretty simple in these cars compared to modern cars. I highly doubt that there's any involvement from any computers, except maybe the Fleetwood since the CCM in that car has its fingers into everything. I may peruse my shop manual and see if I can find any more detailed info on where it is.
EDIT: I found some relevant info, give me a few minutes to upload some pics for you.
Something witty.
schlicky13 is offline
post #3 of 14 (permalink) Old 09-16-2017, 11:49 PM
schlicky13's Avatar
I found the description of the system, and instructions for removing/installing it and the location-ish of the unit. It seems the system uses one single alarm system for key in ignition with door open, turn signal on warning, fasten seat-belt warning, and headlight on warning. Haven't found the relevant wiring diagram(s) yet, but I'll keep flipping through the book, if I find them, I'll add them.
Something witty.
post #4 of 14 (permalink) Old 09-16-2017, 11:59 PM Thread Starter
Thanks, that'd be a great help if you can find it.
CB700S is offline
post #5 of 14 (permalink) Old 09-17-2017, 12:03 AM
schlicky13's Avatar
I found them, just working on resizing them so the forum will let me upload them. Grabbed all the wiring diagrams, another page of descriptive info, and a page with a pin-out for the connector or harness. Only thing I didn't grab were all the flowcharts for troubleshooting and diagnosing the system. Also, did you know there's an option for a catalytic converter temperature alarm? It was for Japan export only, no clue if any were ever actually equipped with it and sent there though. But it is a part of this system if equipped. I learn something new everyday.
Something witty.
post #6 of 14 (permalink) Old 09-17-2017, 12:09 AM
schlicky13's Avatar
Diagrams and pin-out.
Something witty.
post #7 of 14 (permalink) Old 09-17-2017, 12:10 AM
schlicky13's Avatar
Some more description of the system and component location info.
Something witty.
post #8 of 14 (permalink) Old 09-17-2017, 12:14 AM
schlicky13's Avatar
And just FYI, this is from a 1994 Cadillac Fleetwood manual. So the info may not translate 100% to the b-body cars, since as many of us know, the Fleetwood's are weird and often overly complicated in terms of how they were wired up and communicate with the onboard computers.
Something witty.
post #9 of 14 (permalink) Old 09-18-2017, 08:18 AM
The chime module is the green box on the very inconvenient convenience center, beside the steering column, under the dash.
gbhs72 likes this.
post #10 of 14 (permalink) Old 09-18-2017, 09:39 AM
gbhs72's Avatar
Fred, funny & true. Good to see you back here.
Mark: Snowman-33
gbhs72 is offline
