Rewire turn signals - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 01-15-2018, 12:29 PM Thread Starter
Rewire turn signals
I have a 1994 roadmaster sedan. My turn signal switch in the steering wheel emitted little bit o smoke.
Now id like to put a switch on the dash to turn them on manually. Which color wires from the column are for left and right signals?
Milkman is offline
post #2 of 9 (permalink) Old 01-15-2018, 12:33 PM
It's not that simple,due to the brake lights go through the turn signal switch also...
post #3 of 9 (permalink) Old 01-15-2018, 12:49 PM Thread Starter
I just need to figure out which wire closes the 12v on the flasher relays. Those are seperate from the brakes
Milkman is offline
post #4 of 9 (permalink) Old 01-15-2018, 02:19 PM
95wagon's Avatar
As 1slow96 point ed out , it is not that simple.
There is only one left rear "bright" wire and one right rear "bright" wire .
With the switch in the mid "rest position, the white from brake switch wire is connected to the two rear wires to act as brake lamps.
If you turn right , the white brake wire stays connected to the left rear brake , right wire disconnects and the wire from the flasher connects to it and right front.
Turn left, the opposite happens
If you hook the flasher wire to a on-off-on SPDT switch and run each side to the bright lights on each corner, you will get turn lamps, sure, but lose your brake lamps.
See attached.
To answer your question , purple
Name:	turn signal 2.jpg
Name:	turn signal  1.jpg
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #5 of 9 (permalink) Old 01-15-2018, 02:32 PM Thread Starter
Is there not 2 different wires from column that i can use to switch to restore original functions?
also what page is that in the carline book i cant find it? the schedmatic
Milkman is offline
post #6 of 9 (permalink) Old 01-15-2018, 03:01 PM
Be a lot easier to swap out the column,or simply replace the turn signal switch,and/or it's wiring. Than to try re-inventing the wheel...
post #7 of 9 (permalink) Old 01-15-2018, 03:57 PM Thread Starter
Was trying to avoid that. I dont have the right tool to take it apart. I cant find the correct wiring diagram
Milkman is offline
post #8 of 9 (permalink) Old 01-15-2018, 05:23 PM
Get another column then,they're common as dirt.
post #9 of 9 (permalink) Old 01-15-2018, 05:59 PM
B-Bodies came with undersized wiring in the column.
Replace it. That is your only realistic option.
If you tow and have the lights tied in that can cause issues as well as running higher wattage bulbs.
Not having the tool is a poor excuse since most any auto parts store will loan the proper tool.
Rodney
rodney is offline
