need a pic - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 04-14-2018, 10:19 AM Thread Starter
need a pic
Can someone post a picture of the knock sensor wiring connection--------------where the wire connects to the knock sensor. Dummy me can't figure out how to disconnect the wire from the sensor
BH tuning, Transgo shift kit, Eaton posi W/ 3:73 gears, EDGE 9.5" 3000 stall , BMR rear lower control arms. BMR front and rear sway bars Hotchkis springs, CIA trans crossmember; 1.6 Pro magmuim RR; CIA budget headers w/ high flow cats; 2 1/2" cat back with X pipe; chrome dual cone CAI, 52mm throttle body, 30lb SVO injectors, Wilwood brake calipers, Power Stop drilled and slotted brake rotors, Bilstein shocks. Gary's 2 relay headlight harness. Gary's battery relocation harness
my95ss is offline
post #2 of 4 (permalink) Old 04-14-2018, 10:36 AM
Sinister's Avatar
The plug/clip is round. You have to squeeze in the sides and then pull it out.
1995 Caprice Wagon
Sinister is offline
post #3 of 4 (permalink) Old 04-14-2018, 10:37 AM
Take a look at a sensor pigtail...
http://shbox.com/1/ks.jpg
....you just squeeze the sides and pull it off. When you squeeze it it sort of releases its grip on the KS ridge and can be removed.
post #4 of 4 (permalink) Old 04-14-2018, 03:59 PM Thread Starter
Red face
Of course! Now I see
my95ss is offline
