Cruise Control - Chevy Impala SS Forum
 6Likes
post #1 of 17 (permalink) Old 04-20-2018, 09:11 PM Thread Starter
Tank's Avatar
Cruise Control
For the first time in 23 years when I tried to engage the cruise it didn’t work. I have only checked the fuse which is good. Maybe the switch on the stalk just wore out? What are the usual suspects when this happens?
95 DCM SS. One owner. Air pump delete. Tri-Y\'s & cat delete pipes. TB bypass. Powder coated intake by Noble Coatings. Home plate delete. Other wise stock for now.
1967 Chevelle
1947 Mercury
1964 Barracuda
1999 Corvette
2005 Nissan Titan
1999 Honda Valkyrie
Tank is offline
post #2 of 17 (permalink) Old 04-21-2018, 12:16 AM
cruise control in-op
FYI-A burned out tail light bulb or CHMSL will keep the cruise from engaging.
Jim
Tank and gbhs72 like this.
1968 Camaro -my first car.
1995 Purple Pearl B4U Caprice
1995 Black/White 9C1 Caprice--NADACOP
1995 Purple Pearl L99 Caprice
2012 Alto Gray Metallic 9C1 Caprice--The HoDag-Solo axle back exhaust, improved racing OTR CAI intake.
NADACOP is offline
post #3 of 17 (permalink) Old 04-21-2018, 08:37 AM Thread Starter
Tank's Avatar
Jim
Just checked and they are all working.
NADACOP likes this.
1967 Chevelle
1947 Mercury
1964 Barracuda
1999 Corvette
2005 Nissan Titan
1999 Honda Valkyrie
Tank is offline
post #4 of 17 (permalink) Old 04-21-2018, 02:46 PM
Unplug underhood,and spray pins with contact cleaner,and/or WD-40... After messing with the connector some,mine started working again,and has ever since...
Tank likes this.
post #5 of 17 (permalink) Old 04-21-2018, 07:02 PM Thread Starter
Tank's Avatar
Next on my list to try.
1967 Chevelle
1947 Mercury
1964 Barracuda
1999 Corvette
2005 Nissan Titan
1999 Honda Valkyrie
Tank is offline
post #6 of 17 (permalink) Old 04-22-2018, 12:25 PM
If the wiring/circuit check out fine, then it may be the module itself. If you troubleshot this to that point, then you may find this info helpful...
Cruise Control Module Disassemble
GL
post #7 of 17 (permalink) Old 04-23-2018, 01:55 PM Thread Starter
Tank's Avatar
GL
Thanks, I hope it doesn’t come to that though!
1967 Chevelle
1947 Mercury
1964 Barracuda
1999 Corvette
2005 Nissan Titan
1999 Honda Valkyrie
Tank is offline
post #8 of 17 (permalink) Old 05-30-2018, 12:06 PM Thread Starter
Tank's Avatar
Still no luck as I tried cleaning the contacts. I looked at the link above which was good as far as it goes. Shows the disassembly of the unit but no trouble shooting or ideas of possible problem areas.
1967 Chevelle
1947 Mercury
1964 Barracuda
1999 Corvette
2005 Nissan Titan
1999 Honda Valkyrie
Tank is offline
post #9 of 17 (permalink) Old 05-31-2018, 08:38 AM
How many miles on the car/unit? These modules have plastic gears. I have 2 modules with worn out gears. I have used the cruise control heavily on my Impala and wore out the original unit.
Ken Hennessy is offline
post #10 of 17 (permalink) Old 05-31-2018, 08:39 AM
jayoldschool's Avatar
There is a comprehensive and easy to follow troubleshooting tree for the cruise in the FSM. Test something: yes/no, move on to next test. Just with a voltmeter. It will solve the problem in about ten min.
jayoldschool is offline
