4.3v8 pcm - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 05-02-2018, 01:59 PM Thread Starter
4.3v8 pcm
I have a 96 Chevy Caprice 4.3 v8 I got a 96 impala ss part car can I put the 5.7 lt1 in my 96 caprice and get my pcm reprogram for the lt1 or do I need the pcm and wire harness from the 96 impala SS please help thank you
mojoe407 is offline
post #2 of 4 (permalink) Old 05-02-2018, 02:27 PM
babywag's Avatar
just use the pcm from 5.7
babywag is offline
post #3 of 4 (permalink) Old 05-02-2018, 05:04 PM
When I did this conversion in my 95, I was fortunate to get the PCM with the motor and just used that. Pretty sure the 4.3 and the 5.7 have different part numbers for the PCM and not sure if the 4.3 PCM can be programmed to work well with the 5.7. Maybe a PCM tuner company could answer that for you and do that service. The big main difference in engines is the 19lb injectors vs the 24 lb for the 5.7 and the PCM may be part of that equation.
As for the engine harness...they should be the same on both cars. When I swapped mine, I just kept my original 4.3 harness with the 5.7 engine and it was plugnplay.
Btw - I do have a 96 PCM from a 96 9C1 car that I'm parting and could sell it for $50.
post #4 of 4 (permalink) Old 05-02-2018, 08:26 PM
Pretty sure the 4.3L and the 5.7L have different part numbers
same part number for the pcm, different calibration part number for the program put into the functionally identical pcm
Any 96 or 97 OBD2 pcm that operated any LT4, LT1, or L99 engine variant, can have any other calibration loaded into it, so it can then operate any other LT4, LT1, or L99 engine variant.
Your questions have been answered; however, you'll need a tuner to reprogram whatever pcm you choose to provide - unless the programmer also has a pcm to sell, in addition to loading the calibration into it.
The big main difference in engines is the 19lb injectors [for the 4.3L] vs the 24 lb for the 5.7L, and the PCM may be part of that equation.
As said, any 96 or 97 OBD2 pcm that operated any LT4, LT1, or L99 engine variant, etc. In other words, Corvette, Camaro V8, FireBird V8, Fleetwood, RoadMaster, Caprice, same difference.
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
