help with lights in rearview morror - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 05-16-2018, 08:50 PM Thread Starter
2 weeks ago my mirror fell off the windshield and was hanging by the wires---for about a week. Both lights in the mirror were off at that time. While prepping to glue it back on I plugged the wire connector in and one light stays on all the time and the other will not come on at all. Sooooooo I took it apart and didn't really find anything and then I dropped it and well that mirror is now in the land fill. So I buy another mirror from Mr. Impala Auto Parts. This mirror does the same thing. 1 light in the mirror stays on and the other won't come on at all. Is the problem in the connector and wire that goes back up under the headlinner. Can someone point me in the right direction to fix this?
BH tuning, Transgo shift kit, Eaton posi W/ 3:73 gears, EDGE 9.5" 3000 stall , BMR rear lower control arms. BMR front and rear sway bars Hotchkis springs, CIA trans crossmember; 1.6 Pro magmuim RR; CIA budget headers w/ high flow cats; 2 1/2" cat back with X pipe; chrome dual cone CAI, 52mm throttle body, 30lb SVO injectors, Wilwood brake calipers, Power Stop drilled and slotted brake rotors, Bilstein shocks. Gary's 2 relay headlight harness. Gary's battery relocation harness
my95ss is offline
post #2 of 8 (permalink) Old 05-16-2018, 11:53 PM
Z09B4U's Avatar
This would be normal if you had a door open.
Burned out or broken(dropped) bulb.
Z09B4U
Z09B4U is offline
post #3 of 8 (permalink) Old 05-17-2018, 04:20 AM Thread Starter
[QUOTE=Z09B4U;12076010]This would be normal if you had a door open.
Well of course---how stupid of me not to know that
my95ss is offline
post #4 of 8 (permalink) Old 05-17-2018, 10:54 AM
Z09B4U's Avatar
That was my best guess from what you wrote. You still will have to close the doors and check. I like the probable solutions first. You could have a shorted switch and a open switch but most switches get very little use and should be fine. It would seem near impossible to have four switches fail.
I cannot see a way that the wiring harness could cause your issues.
The only bulb information I found was this:
https://www.impalassforum.com/vBullet...t-working.html
#73 seems right. T9 torx will be a pain.
Before I would buy a new bulb I would check the old one. You could use a ohmmeter or switch the placement of two bulbs.
I am sure most people have a story where they took a part something several times before finding out that they forgot to do something to make it function "normally".
Z09B4U
Z09B4U is offline
post #5 of 8 (permalink) Old 05-17-2018, 04:58 PM Thread Starter
Guess what? After I shut the car door and plugged in the mirror---it works But I have to replace 1 bulb. Thanks for the link to do just that!
my95ss is offline
post #6 of 8 (permalink) Old 05-17-2018, 07:45 PM
gbhs72's Avatar
[quote=my95ss;12076025]
This is one of those moments in life.
Mark: Snowman-33
gbhs72 is offline
post #7 of 8 (permalink) Old 05-17-2018, 08:16 PM Thread Starter
[quote=gbhs72;12076153]
Originally Posted by my95ss View Post
This is one of those moments in life. https://youtu.be/g6GuEswXOXo
Mark: Snowman-33
How fitting and how true------------------Thats a good one!
my95ss is offline
post #8 of 8 (permalink) Old 05-20-2018, 05:28 PM
Z09B4U's Avatar
I recommend replacing in pairs. I save and label the old one as a RFE and will use it when I do not have time to shop for a new one.
I have seen some so mirrored that they were useless.
Z09B4U
Z09B4U is offline
