Misfire problem - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 07-16-2018, 07:49 PM Thread Starter
Misfire problem
Misfire problem on my impala 1996 SS I already changed the ignition distributor and still get misfire Any idea what I can be
David W Aviles is offline
post #2 of 12 (permalink) Old 07-16-2018, 09:05 PM
Do you have a CEL on?
Have you scanned for codes?
OBD2 scanners are very inexpensive and code readers only even less.
post #3 of 12 (permalink) Old 07-17-2018, 08:43 AM
Banned
did YOU or some tech replace distributor ? what distributor used [who made it ? ]
if you did the work how did the old dist look any arcing water / oil damage ? any seals replaced ? did you replace the coil and ICM ?
to help you must reveal what parts were changed and how the work was done and other component info when this work is done..
miss fires can be fuel pressure low...................need to measure it .
so who did all this work on engine ?
j cat is offline
post #4 of 12 (permalink) Old 07-17-2018, 01:32 PM
Inquiring Minds Wanna Know -
- All the same things it seems.
- On all 3 threads!
https://www.impalassforum.com/vBulle...-fire-you.html
https://www.impalassforum.com/vBulle...impala-ss.html
96 Black is online now
post #5 of 12 (permalink) Old 07-17-2018, 02:03 PM Thread Starter
I got the distributor from advance auto parts And the misfire that I have is only on the passenger side I change the Spark plug and they wore black Only the passenger side
post #6 of 12 (permalink) Old 07-17-2018, 03:01 PM
Banned
so you did the work ???
what are the miss fire codes or other codes ??? when YOU replaced the distributor did YOU measure the plug wire resistance ???
if you have headers then the plug wires may be burned up on that side ....
j cat is offline
post #7 of 12 (permalink) Old 07-17-2018, 03:38 PM
Or,bad O2...
post #8 of 12 (permalink) Old 07-17-2018, 05:42 PM
Or, cracked manifold..
Or, crossed wires...
Or, even broke manifold bolts..
David, exactly how many plugs are black? Where is the original opti?
post #9 of 12 (permalink) Old 07-17-2018, 06:00 PM Thread Starter
All 4 from the passenger side was black wire look okey
post #10 of 12 (permalink) Old 07-17-2018, 06:01 PM Thread Starter
What is opti
