Temp sensor connector - Chevy Impala SS Forum
post #1 of 17 (permalink) Old 10-24-2018, 04:10 PM Thread Starter
Is this green wire the wire that goes to the temp sensor? If so why is it a single wire and the connector has two wires(pigtail)?
Javi702 is offline
post #2 of 17 (permalink) Old 10-24-2018, 05:32 PM
Probably so they can use the common two terminal connector,and the same connector body on the sender,and the sensor as well. Other position should have a rubbery plug on the connector...
post #3 of 17 (permalink) Old 10-24-2018, 05:34 PM Thread Starter
Okay so if i get a new pigtail how do i install it? Wich wire do i use ?
Javi702 is offline
post #4 of 17 (permalink) Old 10-24-2018, 05:36 PM Thread Starter
Im talking about the upper wire
Javi702 is offline
post #5 of 17 (permalink) Old 10-24-2018, 05:56 PM
jayoldschool's Avatar
The temp sender in the side of the head is the one that sends to the dash gauge. One wire, that little green wire. Mine has broken a couple times. I just made an extension for it, thicker gauge, double insulated with two layers of loom cover, then aluminum tape. F you little green wire!
jayoldschool is offline
post #6 of 17 (permalink) Old 10-24-2018, 06:20 PM
I tend not to use "pigtails",but prefer to splice heavier wire downstream. Then,crimp/solder a new Metri-Pack terminal/seal,and install to the proper side of original connector shell...
post #7 of 17 (permalink) Old 10-24-2018, 06:29 PM
Originally Posted by jayoldschool View Post
.... thicker gauge, double insulated with two layers of loom cover, then aluminum tape. F you little green wire!
That should just about do it. But please tell me you didn't forget to load up the loom cover solid with copper RTV. lol
96 Black is online now
post #8 of 17 (permalink) Old 10-24-2018, 06:35 PM Thread Starter
Okay but my main question is there is only 1 green wire and the new pigtail connector with the plug has 2 which wire do i connect it to?
Javi702 is offline
post #9 of 17 (permalink) Old 10-24-2018, 06:35 PM Thread Starter
Or do i just connect the 2 to the 1 green wire?
Javi702 is offline
post #10 of 17 (permalink) Old 10-24-2018, 07:15 PM
Suppose one could,or see which side the sender pin is on....
