Lack of dash and running lights - Chevy Impala SS Forum
 1Likes
post #1 of 41 (permalink) Old 01-06-2019, 08:47 AM Thread Starter
Swtgrl2no's Avatar
Hi , so.. (1996 caprice 4.3) day before yesterday I lost my dash and running lights. All other lights are working no prob. Fuses are good but not getting power to 41 42 and 43. I am thinking its perhaps the headlight switch. That presents two problems. 1 ripping into 3/4 of the dash to get to it and 2 NO ONE has one! Its discontinued and even no longer aftermarket! Anyone have a testing and repair procedure? I have basic lights not twilight sentinel and not dtr. Switch pic below. Thanks so much for any help.
Swtgrl2no is offline
post #2 of 41 (permalink) Old 01-06-2019, 10:23 AM
Fair to large number of hits with "no dash lights" - I assume you checked those already. Multiple threads reference simul. dash/tail probs. It took this guy over 2 weeks but he finally resolved similar issue(s):
https://www.impalassforum.com/vBulle...il-lights.html) It took
j cat likes this.
post #3 of 41 (permalink) Old 01-06-2019, 10:45 AM Thread Starter
Swtgrl2no's Avatar
Yes a week of scouring the internet the library. Probing and poking wires all but pulling the dash apart. 98% of what I found spoke of twilight sentinel and dtr neither of which I have. As for trying a new switch that seams impossible as none can be found! All fuses test good. No power to mentioned fuses.
post #4 of 41 (permalink) Old 01-06-2019, 12:06 PM
gbhs72's Avatar
If it is the head light switch, Rock Auto has 2 of them. They are pricey. https://www.rockauto.com/en/moreinfo...037494&jsn=482
Mark: Snowman-33
gbhs72 is offline
post #5 of 41 (permalink) Old 01-06-2019, 12:21 PM Thread Starter
Swtgrl2no's Avatar
Yeah OUCH! now I definitely want a way to test before I make that plunge. Oreily showed they could get same ones but turned out they couldn't. Hopefully it's not the same for rockauto.
post #6 of 41 (permalink) Old 01-06-2019, 12:27 PM
Z09B4U's Avatar
The TW circuit can be ignored if you do not have it.
The 1994 diagram is different than the 1996 I am looking at.
You did not mention anything about Fuse#31 which powers the tail light and instrument lamp fuses. These are the only two fuses connected to #31 in the 96 diagram.
Goldswagon Wiring Diagrams
Look at the headlamp DLR or Twilight, external, and instrument diagrams.
Are you looking at the right circuit diagram or fuse box diagram? The 1996 seems to be different.
I just pulled out a 1996 Owners manual. I see it shows 41,42, and 43. Does not match with Goldswagon diagram.
For 94-96 it seems that these fuses are supplied by #31.
Z09B4U
Z09B4U is offline
post #7 of 41 (permalink) Old 01-06-2019, 01:32 PM
That's more what I was driving at. The OP may not presume to walk around the back of the car if the dash/running are out. No power to the first mentioned fuses may be fed from an upstream block fuse. That's what I was half-conjecturating from the thread I linked up there.
Final thought - I'd be hunting slightly earlier work on the car that may have messed up a ground, or, find those upstream fuses/breakers/relays whatever, v. zooming in on the switch. Sure they go bad, but unless some special abuse/overuse the other stuff's more probable.
post #8 of 41 (permalink) Old 01-06-2019, 01:37 PM
Banned
no power to the fuses 41/42/43 .. you have no park lamps working but the headlamps work so with my work looking this up on my OEM 1996 B body diagram the fuse maybe #31 label ext LPS fuse 20amp.
now if you had no headlamps "also" then it would be the fuseable link A..that feeds both park and headlamp power to the operator dash control switch .. good luck ..
If I posted the diagram forum would dump it quickly ..
j cat is offline
post #9 of 41 (permalink) Old 01-06-2019, 03:36 PM Thread Starter
Swtgrl2no's Avatar
That fuse looks fine too.. I'm going to try replacing it and see.. ya know the ol looks fine but still bad
post #10 of 41 (permalink) Old 01-06-2019, 04:24 PM
Z09B4U's Avatar
You are wasting time without a test light or voltmeter.
Fuse #31 is fed by a fusible link. The horn is fed by the same fusible link(as per Goldwagon's diagram). Does your horn work? If it was a 94 I would ask you if your headlights worked.
There is no point in testing anything else unless you verify voltage on both sides of fuse #31. You cannot blame the headlight switch if it is not getting power.
Z09B4U
Z09B4U is offline
