AutoMeter Custom Gauge Faces - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 02-04-2019, 08:54 PM Thread Starter
juniorwatson's Avatar
I had just posted to the MISC section about AutoMeter's current discounts, and while on their webpage, I happened to clink on a link for custom stuff.
I had no idea that having customized faces was available thru their 'Custom Shop' website. Anyway, I thought I'd post here in case any of y'all have some extra bucks to spend and you'd like to have your gauges be something unique to you.
AutoMeter Custom Shop
Here's a partial screeen shot with the skulls as an example
Welcome to Auto Meter Custom Shop Custom gauges. That's what it's all about. The world’s finest performance instruments are now available to you in nearly infinite configurations. Limited only by your imagination; your dash can now display the same level of individuality as your ride – all with Auto Meter’s legendary quality and attention to detail
juniorwatson is offline
post #2 of 3 (permalink) Old 02-05-2019, 08:36 AM
Speedhut is another gauge maker that offers custom faces and bezels
BALLSS is online now
post #3 of 3 (permalink) Old 02-05-2019, 11:37 AM
angelo's Avatar
neat
Well i tried to mess around. $919 is a little out there...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
Similar Threads
what guage faces on your camaro cluster? Interceptor9C1 Interior 3 01-14-2010 07:48 PM
'Gauging' interest in cluster faces Cmdr. Flash Gumby Roadmaster 10 06-09-2008 10:01 PM
Baby with two faces...... KW Baraka Misc. 46 04-10-2008 09:13 AM
How come my FSM dosnt have the connector faces? BigB9000 Concerns 11 01-04-2008 10:53 PM
Anyone have these white gauge faces? CscottsSS Interior 2 05-07-2003 08:18 PM
