95 Impala speedo and volts inop - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 02-25-2019, 06:25 PM Thread Starter
Bigdawg70's Avatar
Trying to find out where power is given for the speedo and volt in dash. I can pull cluster and bench test but i do not appear to have any power in the car when checking A5. any help is appreciated
Always a work in progress
Bigdawg70 is offline
post #2 of 3 (permalink) Old 02-26-2019, 06:05 PM
If your just after Schematics, I have found this website helpful for tracing out circuits. He has most there that I ever need and there are also online services that will sell you a complete Schematic set for about $10-$20...I got a PDF file for my 95 from them years ago.
http://www.goldsswagon.com/diagrams/wiringindex.htm
post #3 of 3 (permalink) Old 02-27-2019, 07:38 PM
Jimpala95's Avatar
Check fuses 11,20,33 and 42. All in left side dash fuse center.
Jimpala95 is offline
Similar Threads
201 amps at idle and 14.3 volts 92SS wagon Electrical 42 06-23-2011 08:41 PM
Battery Volts Drops And The Car Will Die pooney1983 Engine Problems/Maintenance 5 03-12-2010 02:36 PM
Volts drop to 13 on low, 13.5 on medium, and stays steady at 14 volts on high tylert14 Electrical 13 03-07-2007 07:11 AM
Temp Gauge INOP and Remote Start INOP TurboLT1 Electrical 3 02-01-2007 05:50 PM
Fuel and Volts guages are dim. Is it just me? Bugman Interior 1 11-24-2006 11:30 PM
