Starter terminal torque spec? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 03-14-2019, 05:07 AM Thread Starter
Big Jack's Avatar
Hi guys, when installing a new starter I snapped the copper stud that the battery cable connects to.
Does anybody know what are the torque spec for the battery cable nut & solenoid cable nut?
Thanks
Remember, when not sure what to do, hit the throttle.
It may not end well, but at least it'll end the suspense.
Big Jack is offline
post #2 of 4 (permalink) Old 03-14-2019, 06:47 AM
juniorwatson's Avatar
Thanks
"Starter Solenoid Switch-to-Battery Positive Cable Nut: 10N-m (89 Lb. in)"
I don't see a torque specification for the smaller gauge wire for the solenoid actuation. That's always a 1/4" drive tool set, and typically using a 1/4" or 5/16" socket. That's a snug connection only, especially since it's only a #6 or #8 size stud!
juniorwatson is offline
post #3 of 4 (permalink) Old 03-14-2019, 05:32 PM Thread Starter
Big Jack's Avatar
Thanks. I got the starter back together & on the car. Now the engine cranks but won't fire. Engine ran fine 4 days ago. Any ideas? All I've done since is replaced starter. Car has about 1/3 tank of fuel & front end is still up on jackstands (not sure if this would make a difference).
Big Jack is offline
post #4 of 4 (permalink) Old 03-14-2019, 05:49 PM
https://www.impalassforum.com/vBulle...-no-codes.html
Meh, I've broken the brass stud too. They still use the same cheap bakelite as the '40s lol. We don't need no stinkink in./lb. torque wrench! I learned just to tighten til the split lock washer is flattened.
96 Black is online now
Similar Threads
Need torque spec ChriSS K Engine Performance 6 05-21-2010 10:47 PM
Diff cap bolt torque spec? Bugman Drivetrain 6 11-06-2009 04:28 PM
Is Wheel Torque Spec Measured Cold or Hot? Erik Wheels & Tires 27 01-27-2009 10:05 AM
Diff. Cover Torque spec? 05SSS Engine Problems/Maintenance 12 11-28-2007 10:11 PM
SPEC stage 4 is IN! (was: spec 4 gets put in tomorrow) fasst94impalass Drivetrain 15 12-27-2004 12:22 PM
