Fuel Pump Dessected - Chevy Impala SS Forum
 1Likes
  • 1 Post By HUF
post #1 of 8 (permalink) Old 04-08-2019, 11:35 PM Thread Starter
HUF
HUF's Avatar
Fuel Pump Dessected
Finally found time to cut off the aluminum shell and disassemble the original fuel pump with 124,000 miles and almost 24 years on it. As you can see there is a bit of rust but nothing to affect functionality. The only defect I found INSIDE of the pump was a broken wire for positive brush. Nevertheless, the pump worked but did not provide enough fuel pressure. The positive brush was also two times shorter than the negative. What surprised me is the fact all the plastic burning you see in one of the pictures was around negative brush area. The connector to the pump did not melt, but the insulation of black ground wire was quite fried. I replaced that pump with Spectra seven months ago, but left the original wiring. Probably a big mistake since I had an intermittent non-start condition two months ago, which I am afraid is fuel pump/wiring related.
There’s nothing as permanent as a temporary solution.
1995 Cadillac Fleetwood Brougham 122,XXX miles.
HUF is offline
post #2 of 8 (permalink) Old 04-09-2019, 06:18 AM
Originally Posted by HUF View Post
....but left the original wiring. .......
Uh Oh. I'd just bite the bullet and do a do-over with a new harness while your memory is relatively fresh on the r & r. Add a new sender while you're in there. Crimp the lugs down for a tightest possible connection, or some guys solder the wires. Is it ??Airtex?? makes a harness with thicker gauge wires?
EDIT: Interesting that little impeller and housing can build all that pressure. Reminds me exactly of the same parts on the miniature aquarium pump in my wall waterfall.
post #3 of 8 (permalink) Old 04-09-2019, 08:06 AM
I soldered mine in with double wires.
post #4 of 8 (permalink) Old 04-09-2019, 07:25 PM Thread Starter
HUF
HUF's Avatar
Here is an in-tank harness sold by Spectra. Looks pretty solid, but the wires for the sending unit seem to be even thinner than the original ones. I absolutely hate when GM saves on wiring gauge.
I have attached a few pictures of intank wiring I took during the replacement of the fuel pump. The black ground wire has a bit fried insulation, but did not look too too bad.
HUF is offline
post #5 of 8 (permalink) Old 04-09-2019, 08:02 PM
gbhs72's Avatar
I knew I had followed a thread on a Fleetwood and the fuel pump. I know this isn't what you've got but it may give you some ideas. https://www.impalassforum.com/vBulle...fleetwood.html Prost
Mark: Snowman-33
gbhs72 is online now
post #6 of 8 (permalink) Old 04-09-2019, 09:44 PM Thread Starter
HUF
HUF's Avatar
Mark: Snowman-33
Thank you for the link. I wish I had budget and time to do such a great job. The man seems to be perfectionist. I used to be he same way. Not anymore.
HUF is offline
post #7 of 8 (permalink) Old 04-09-2019, 10:13 PM
gbhs72's Avatar
Just trying to help out. A reminder. Read your Sig.
Mark: Snowman-33
post #8 of 8 (permalink) Old 04-09-2019, 10:16 PM Thread Starter
HUF
HUF's Avatar
Haha! I'll most likely find another temporary solution.
gbhs72 likes this.
HUF is offline
Similar Threads
External Fuel Pump into Stock Fuel Pump Harness bad_94_ss Electrical 1 04-02-2012 11:42 AM
Fuel pump replacement 1/2 done!! Need a new fuel pump to go in, forum's preferences? claSSic Caprice Engine Problems/Maintenance 4 01-16-2012 10:26 PM
93 capirce 9c1 350 blowing fuel pump fuses before and after new fuel pump slammed93 Caprice 4 04-26-2011 09:25 AM
New Fuel pump VS old fuel pump resistance. ghetto wagon Engine Problems/Maintenance 0 03-24-2010 10:26 PM
Fuel pump won't prime but fuel pump is NOT bad. What could be wrong? SSlumpin Imp Engine Problems/Maintenance 10 05-18-2009 08:24 AM
