Ignition switch to NASCAR Style toggle switch Panel - Chevy Impala SS Forum
 2Likes
post #1 of 16 (permalink) Old 04-20-2019, 06:21 PM Thread Starter
Question Ignition switch to NASCAR Style toggle switch Panel
Hi , so I am gonna eliminate the ignition switch altogether and make up a panel with big ole toggle switch's ....my kids will love it and the car is on its last legs. Wal Mart destroyed the switch and this 9c1 is headed for the junk pile. but before i do it will serve me for one more summer.
I have the column c1 and c2 connectors in hand. looking at the diagram in the factory electrical diagrams page 11-07-94 - section, 8a-10-3 it kind of looks like i could use 3 on/off toggle switches.... one each for the ORANGE , PINK, & BROWN AND Then a Momentary push button for yellow wire--- start circuit.
Just want to make sure that i should supply each one of those with 12 vdc and not ground. (edit: I think each circuit requires 12 v) but the factory manual is vague.
anyone done this?
Thanks
95 DCM, 95 9c1 Lazer Metalic Blue http://www.cardomain.com/ride/531114/2
Globemaster is offline
post #2 of 16 (permalink) Old 04-21-2019, 10:37 AM
Z09B4U's Avatar
Hate to burst your bubble but what you are suggesting is not simple or cheap.
Rock Auto has new ignition switches starting at $10. I expect a new one would be less than $40 locally.. If your lock cylinder is bad shopping around would get it replaced (with you doing some work) for under a $100.
The ignition switch is made up of 6 separate multi-position switches. Some use ground most use +12V. Some of these circuits require over 30 Amps. Cheap switches will burn out (most are 15Amp or less). So you would also need multiple relays. Simple switches and relays may not do the self tests that are normally preformed by the ignition switch.
To safely replace the ignition switch will cost you way more than fixing the OEM. Off the top of my head 3 switches, 8 relays, crimp connectors, and other shop supplies.
Some circuits need ground some need the specific +12V circuit designed to power each switch.
If you are not very sure how the ignition switch works and how to safely reconnect each circuit you are at risk of high currents starting a fire.
A NASCAR switch panel is connected to complicated circuits.As a example the battery relays they use to disconnect the battery cost about $300, but you just see a simple switch.
Z09B4U
Z09B4U is offline
post #3 of 16 (permalink) Old 04-21-2019, 12:23 PM
I nearly did not click as the mod seems little more use than helping thieves. Glad I read as provides quite good intel - thanks ZO-
Now Globemaster, you know your way around an FSM, so sorry but just can't shake WTH you letting WalMart anywhere near your car. Do you really hate it that much??
96 Black is online now
post #4 of 16 (permalink) Old 04-21-2019, 06:34 PM Thread Starter
yea, It was 20 below zero and i had to have some tires......I figured what could go wrong! My sons bronco project was stalled in the garage and I had no place to pull the tires off. The 9c1 is just beat to hell and 2nd gear is slipping,198000 miles and my wife is done with me having it and I don't have a place to park it. (I never drive my SS anymore cause i live in the middle of MT and main street is dead.)
The next phase is to make a daily driver out of my SS and enjoy it.....so the 9c1 is going to go.
post #5 of 16 (permalink) Old 04-22-2019, 06:54 AM
I figured as much. Spent 9C1 loses to wife = wise tack. Now I just hope she appreciates how much you must love her turning a "never driven" SS into a driver. In Montana.
gbhs72 likes this.
post #6 of 16 (permalink) Old 04-23-2019, 10:33 PM Thread Starter
lol yep..wife .just banned my son from driving the nice car so now the beat to hell 9c1 "with a huge dent in the roof from a baseball' is on the list for repair. wife is on board....never lie to mom. any one know where i can get the linkage that connects the rod to the gear on the ignition switch? took the column down and found the problem.
Thanks....still think the original plan would have looked cool .....just dont want to go to the trouble of building up the 3 circuits that would handle the current.
post #7 of 16 (permalink) Old 04-24-2019, 12:23 AM
gbhs72's Avatar
Classic industries has the rack and a complete kit to rebuild the top of the column. https://www.classicindustries.com/sh...ctuator%20rack
Mark: Snowman-33
gbhs72 is offline
post #8 of 16 (permalink) Old 04-24-2019, 06:51 AM
I may have one. Here is a picture of it.
Name:	ignitio switch part.jpg
post #9 of 16 (permalink) Old 04-24-2019, 10:05 AM
Z09B4U's Avatar
For diagrams and part names:
Steering Column Parts, Replacement, & How to Instructions
Z09B4U
Z09B4U is offline
post #10 of 16 (permalink) Old 04-24-2019, 11:42 AM
One of the dumbest GM designs ever. Basically unchanged for 30 years. Pot metal castings guaranteed to break at the worst time. I assume the new parts are better.
grandpas wagon
grandpas wagon is offline
Similar Threads
Racing Style Toggle Switches FS Phatboi71 Parts for sale/wanted 0 10-18-2010 07:10 PM
WANTED toggle for window switch jbmayjr Interior 1 08-18-2007 07:12 AM
WANTED window switch toggle jbmayjr Electrical 0 08-17-2007 06:46 PM
A Day at a NASCAR race... from a non-NASCAR fan. impala_1995_ss Misc. 26 02-26-2007 09:00 PM
Toggle switch for interior lights AdioSS Interior 5 11-13-2000 10:38 PM
