High Amp Alternator - Chevy Impala SS Forum
 1Likes
post #1 of 13 (permalink) Old 05-19-2019, 11:15 PM Thread Starter
4x4high's Avatar
High Amp Alternator
Has anybody used a high output alternator from this place? If so I'm looking for your feedback pro's or con's.
https://www.powerbastards.com/products.asp?cat=136846
1996 DGGM Impala SS
4x4high is offline
post #2 of 13 (permalink) Old 05-20-2019, 08:53 AM
jayoldschool's Avatar
I wouldn't:
https://www.cadillacforums.com/forum...or-failed.html
jayoldschool is offline
post #3 of 13 (permalink) Old 05-20-2019, 08:57 AM
lol Jay, overpost....
I usually check BBB and google '[insert name] complaints' on any new something I'm contemplating. I checked early this morning and interesting hits re: this co. on TBSS and other forums like you found.
It almost halfway sounds like their stuff does not operate properly with cars where the alt. communicates with a pcm. The neatest thing was finding that goofy youTube with 6 red alts. hooked together.
post #4 of 13 (permalink) Old 05-20-2019, 09:17 AM
babywag's Avatar
Find a local auto electric shop and have yours rebuilt+upgraded.
Way too many folks (IMHO) have problems with online alternator vendors.
babywag is offline
post #5 of 13 (permalink) Old 05-20-2019, 11:48 AM
Reminds me of what I went through with a high output Quick Start alternator I bought for my truck. Failed within months. Couldn't get a response to email or phone calls. Finally got a replacement that didn't last more than a couple days.
James Paley
-95 Caprice Wagon, 93K, 2.56 gears, No-Slip Locker, Sonnax Line Pressure Booster, 2nd and 4th super hold servos, MSD Cap/Rotor, Jacobs high voltage coil, Global West front springs (760lb/in) with Koni Special D front shocks.
Impala SS rim refinishing in progress, 1.6 ultra pro mags and Bullet vs2700 springs waiting for install
-2011 Caprice 9C3
Jim Paley is offline
post #6 of 13 (permalink) Old 05-20-2019, 04:29 PM
Any company that says no mods are necessary, as Power Bastards does, should not be trusted. Good 200 and 250 amp units are available ($$$), but it is worthless to install it without upgrading your cables. Why do think you need more output? Do the cables first and see how much better it is with that alone. Have you had your alternator tested - I mean really tested - on a load type tester?
For those needing a stock unit, check this out:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
It's been on my watch list for years, the price is steadily dropping. I'm still on my original, but will buy this as a spare.
grandpas wagon
grandpas wagon is offline
post #7 of 13 (permalink) Old 05-20-2019, 05:34 PM Thread Starter
4x4high's Avatar
I already have the big 3 cables from Gary at Innovative Wiring so no issue there. My concern is that I'm installing a 1000 watt stereo system and I'm running a Meziere electric water pump and I just want to make sure I'm not under powered. I might be having an intermittent low idle charge issue at the moment so thought why not just upgrade rather than staying with the factory 140amp unit. I'm going to positively check amp output at idle this evening before I leave work (I'm a heavy equipment mechanic).
1996 DGGM Impala SS
4x4high is offline
post #8 of 13 (permalink) Old 05-20-2019, 09:04 PM
gbhs72's Avatar
Have you thought about Jeg's or Summit? They have plenty at a better price and better known names. Then too there is the fact that you can trust from whom you bought. Both are always concerned with their reputation. Free shipping too.
Mark: Snowman-33
gbhs72 is online now
post #9 of 13 (permalink) Old 05-20-2019, 09:46 PM Thread Starter
4x4high's Avatar
Mark: Snowman-33
Yes I was looking at one on Summit Racing. They just dont give any detailed specs like amp output at idle or maximum output at what RPM.
1996 DGGM Impala SS
4x4high is offline
post #10 of 13 (permalink) Old 05-20-2019, 10:08 PM Thread Starter
4x4high's Avatar
I forgot to check my alternator amp output before I left work so I just did now and discovered that my primary fan isnt working (I'll figure that out tomorrow). With the headlights, electric waterpump, AC, and stereo on (no amplifier hooked up yet) the alternator is putting out 90 amps, if I turn the AC off so the secondary fan isnt running it drops to 68 amps. As you can see I will quickly be approaching the max limits of the factory 140 amp alternator.
1996 DGGM Impala SS
4x4high is offline
Similar Threads
200 amp HIGH OUTPUT Alternator BRAND NEW impalass_fan Parts for sale/wanted 7 08-14-2010 05:13 PM
A/C fan works mainly on high & extra high Jim Spahr Electrical 15 07-01-2009 05:26 PM
Increasing idle speed for high amp alternator scoob8000 PCM Programming/Engine Management 5 06-20-2008 08:46 PM
Anybody try Dual Rectifier Alternator from Alternator parts.com? chrisluke50 Electrical 1 04-23-2008 04:20 PM
batcap versus high amp alternator husaman Audio 9 12-28-2006 09:32 AM
