Spark Plug wires, custom length - Chevy Impala SS Forum
 1Likes
  • 1 Post By Blue Wail
post #1 of 2 (permalink) Old 06-03-2019, 11:42 AM Thread Starter
boofers's Avatar
Hey all, is there a length limit to spark plug wires? Reason I ask is because I have the Torqhead system with the spider ignition coil (sits atop the intake), and the plug wires that came with the setup weren't long enough to run them all the same way. So I'd like to make the wires longer and route them through the rear of the motor to the plugs, but wasn't sure if there is a limit. thanks
1996 BBB, 396ci Golen LT4, Yank 3600, TransGo shift kit, 3.73s, P71 MMC driveshaft, CIA Tri-Y Gen II, X-Pipe, Dynomax UltraFlo exhaust, Hotchkis Sway bars & Springs, Bilstein Shocks, UMI extended control arms, ODBI conversion, all installed and tuned by Mike Harris
boofers is offline
post #2 of 2 (permalink) Old 06-03-2019, 01:47 PM
Blue Wail's Avatar
As long as you don't make them 4 foot or longer,
you'll be ok ;^)
Nab
4DoorSS likes this.
Blue Wail is offline
