no blinkers or marker lights - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 07-25-2019, 10:15 AM Thread Starter
Angry no blinkers or marker lights
i have a 1995 impala ss and im having some issues with the lights. the hazards work fine but i have no front parking lights and no directionals. any insight would be a huge help!
Tombones1983 is offline
post #2 of 4 (permalink) Old 07-25-2019, 10:28 AM
47 hits using a couple of words in your post, several threads with titles nearly identical to yours. In the absence of any comments on diagnosis you've performed, start here: https://www.impalassforum.com/vBulle...t-working.html
post #3 of 4 (permalink) Old 07-25-2019, 02:30 PM Thread Starter
i searched those posts and none of them had they same symptoms. some where close but not the same as mine. i thought id give it a shot to just ask a bunch of guys that are smarter than me in hopes that someone has dealt with it already. buying a volt meter today and will come back with results.
post #4 of 4 (permalink) Old 07-25-2019, 06:45 PM
A VOM is de regueur for most all red-blooded mal- -people. An FSM = better. Comb the stickies in Engine Prob/Maint. for the link to GOLDSSWAGON wiring diag. if you want to chase circuits. If you think you've got something way more complex than others, then add some background for more useful responses and suggestions. Are you using LEDs? Did you check EVERY bulb for proper function? The Hazards have their own flasher v. other lights - check that out. Was failure immediate one day, or gradually increasing episodes until permanent? Any other recent work especially electrical before this glitch?
