95 LT1 w Digital Dash issues - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 09-06-2019, 09:53 PM Thread Starter
HzEmall's Avatar
have a 95 LT1 with these digital dash.
The digital part and the gauge illumination ONLY come on when the park light's and then dash light dimmer is turned up and turns the dome light on.
Anyone seen this? have a 95 LT1 with the digital dash.
Anyone seen this?
Tim Baillie
Owner/Fabricator/Specialist
Be Better...Think Different...
1991 Buick Roadmaster Wagon (Dewoodied, not by choice)
Originally Posted by Jimmy Shine
You never stop learning in this business......regardless of what you know or what you think you know.....be humble.............shut your mouth and open your ears and eyes..................man...........you pick up an awful lot...........
Our Site
Our Blog
HzEmall is offline
post #2 of 3 (permalink) Old 09-07-2019, 10:28 AM
Anyone seen this?
I know the thumbwheel spins up and down.
Does anything happen when you try (as weird as this sounds) to wiggle the thumbwheel from side to side?
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
post #3 of 3 (permalink) Old 09-07-2019, 12:22 PM
Z09B4U's Avatar
When the solder cracks on these circuit boards all sorts of things happen. Have a look at the STICKY:
https://www.impalassforum.com/vBulle...splay-fix.html
ShudahadaV's documentation of cracked solder on the board fixes most issues.
Your problem may just be bad car connector to the cluster. Have you unplugged the cluster? If that "fixes" it spray the plugs with contact cleaner (not WD-40). Just handling the cluster may flex the circuit boards and temporarily make contact. If it fails again soldering the board pins may be the fix.
Z09B4U
Z09B4U is offline
