AC not blowing cold - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 04-18-2005, 09:43 PM
95pimpala
Unhappy
Im trying to get ready for the summer so i recently turned on my ac... to my suprise it was blowing hot air. I checked the freeon pressure and it was fine, the compressor was engaging like it should but i still was getting hot air...so i changed the orofice and recharged the system but it still blew hot air.
post #2 of 3 (permalink) Old 04-19-2005, 02:59 PM
HEAVYSS
You probably should of posted this in the Engine Maintenance/Problems or Misc sections.
Sounds like your compressor is done. I bet if you do a pressure check on the low pressure side, it will read high. Not sure the exact numbers, but the pressure kit has instructions. Never try to charge a compressor that is reading high on the low side . If you're using one of the kits from the auto parts store, you could end up with an explosion.
post #3 of 3 (permalink) Old 04-25-2005, 07:53 PM
RJI
What are the reading? High and Low preasure along with the outside air temp.
