rearend swap - Chevy Impala SS Forum
post #1 of 16 (permalink) Old 11-16-2014, 01:25 AM Thread Starter
Post rearend swap
Can a 95 9c1 rear end with a 3.73 gear differential fit on a 93 Buick road master with the tow package? Please help!!
93Roady is offline
post #2 of 16 (permalink) Old 11-16-2014, 09:51 AM
2ndtonone's Avatar
physically yes, but are disk or drum brakes? reflash the computer for the gears. possible drive train vibration? new high speed drive shaft?
its' not easy, but someone has to do it
2ndtonone is offline
post #3 of 16 (permalink) Old 11-16-2014, 11:39 AM
Small vendor
BigBlackBeaSSt's Avatar
Yes it will work. You will have to re-calibrate your spedo, but I believe the TBI cars did this via a new gear in the tranny. No re-program necessary. 3.73:1 ratio should not cause you any troubles with vibration unless something is not correct to begin with. The disk will work fine. If you do the brake bolt mod it would make the discs more effective.
If you have the tow pack what rear do you have now? Some of the Roady Sedans (assuming we are talking about a sedan) tow pack cars came with 3.73:1 gears.
BigBlackBeaSSt - 94' BBB lots of mods.*** 94 DGGM Woody Wagon to many mods to list
PM ME FOR BLEEDER VALVES.
BigBlackBeaSSt is offline
post #4 of 16 (permalink) Old 11-16-2014, 02:22 PM
Correct but it well documented that the stock driveshaft will cause vibration that the 3.08s don't really show until it spins faster with the 3.73's. The 3.73 will show a problem with the DS that the 3.08 never had.
I never really noticed a problem with vibration when cruising up to 80-90 MPH until I swapped in another rear with 3.73 gear. With 3.73 I would get a small but noticeable vibration at about 65-70 MPH. Switched over to a balanced Dynotech DS and the problem was instantly fixed.
BTW - check for posts by member Goldmaster. He has done this swap in a RM before and may have some info that would be helpful.
post #5 of 16 (permalink) Old 11-16-2014, 06:32 PM Thread Starter
Thank you both for that info, it is a 93 RMS and it has a hitch on the back so I'm assuming I have at least 2.92's in it now. I doubt that it had the 3.73's in it already because it doesn't pick up fast enough to have that feel to it and it currently has drum brakes on it
93Roady is offline
post #6 of 16 (permalink) Old 11-16-2014, 06:33 PM Thread Starter
And I will definitely look up Goldmaster's post thanks
93Roady is offline
post #7 of 16 (permalink) Old 11-16-2014, 09:11 PM
Small vendor
My impala ss and wagon both had 3.73 and stock drive shafts and neither had an issue. Luck of the draw I guess.
post #8 of 16 (permalink) Old 11-16-2014, 09:48 PM Thread Starter
How is the gas mileage on the 3.73's?
93Roady is offline
post #9 of 16 (permalink) Old 11-17-2014, 06:43 AM
It will go down a little, but there are obvious trade-offs as you will turn more RPM's when crusing. You are also making the car more spirited to drive and your right foot will help dictate how many MPG's you will lose.
This has been discussed quite a bit before. Just get familiar with the search function and you will find lots to read.
post #10 of 16 (permalink) Old 11-17-2014, 06:51 PM Thread Starter
Thank you I appreciate the info again
93Roady is offline
