changing tranny fluid on a roadmaster - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 05-24-2012, 07:52 AM Thread Starter
broderick's Avatar
just looked at my '95 roadmaster trans fluid plumbing and it doesn't have the clamp on line up front by the radiator like the SS or the 9C1 that is used by many to drain the trans fluid. all the connections are threaded. anyone encountered this before and have solution?
I'm thinking I could just cut the rubber hose line and do the the fluid draining then reconnect with a brass barbed hose connector and clamps. any thoughts on that?
Broderick
on my 4th b-body - 96 b4u
had: 96 9C1 bought new
95 Roadmonster
91 9C1
broderick is offline
post #2 of 4 (permalink) Old 05-24-2012, 11:28 AM
Sophomore Member
I've done it that way on other cars. You're not the first to encounter this on a B-car. Other option is to just unscrew a line from somewhere and don't cut it at all.
sherlock9c1 is offline
post #3 of 4 (permalink) Old 05-24-2012, 11:57 AM Thread Starter
broderick's Avatar
don't matter which one to unscrew?
Broderick
95 Roadmonster
91 9C1
post #4 of 4 (permalink) Old 05-25-2012, 10:14 AM
Sophomore Member
Pick the easiest one to get to that will unscrew.
