New windshield - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 08-21-2012, 07:08 AM Thread Starter
8upRMS's Avatar
New windshield
If I replace the windshield is there a new seal I need to get on a roadmaster?
8upRMS is offline
post #2 of 4 (permalink) Old 08-21-2012, 09:10 AM
hooligan's Avatar
no
the windshield is held in place with urethane adhesive.
96 RMS Limited
hooligan is offline
post #3 of 4 (permalink) Old 08-21-2012, 02:41 PM
The gasket on the top must be replaced. See FSM.
grandpas wagon
grandpas wagon is offline
post #4 of 4 (permalink) Old 08-21-2012, 05:54 PM
The top reveal molding is usually destroyed when removing the glass. You can get a universal one that is smooth, or an OEM style that has a groove in it.
The bottom is the hardest part to get off, because it is at an angle from the outside, and the inside is blocked my the dash pad. If you have the glass, removing the old one with a wire is possible. You should remove the A pillar trim inside and the side reveal moldings from the outside. You also have to remove the cowl to access the front.
