how to make the outside temp in Celsius - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 11-03-2012, 12:34 PM Thread Starter
the outside temp comes in F
i would like to alter them to show celsius
is it possible
thanks in advance
buick owner is offline
post #2 of 5 (permalink) Old 11-03-2012, 03:38 PM
94MI9C1's Avatar
If you are talking roadmaster, there is a pin/wire to ground behind the climate control head. I will have to dig it up for you.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #3 of 5 (permalink) Old 11-08-2012, 11:37 PM
i want to change temp.
from F to C
i think we can change it because there is C symbol in the red Circle
902907 is offline
post #4 of 5 (permalink) Old 11-14-2012, 06:55 AM
ARCStig's Avatar
Send a message via AIM to ARCStig Send a message via MSN to ARCStig Send a message via Yahoo to ARCStig Send a message via Skype™ to ARCStig
Looks like they took the button off the newer models, on my older climate control module, there is a dedicated button to switch.
ARCStig is offline
post #5 of 5 (permalink) Old 11-14-2012, 08:53 PM
94MI9C1's Avatar
yeah you have to ground a pin on the back of the unit. Ground pin D7 on the HVAC control and it will be in Celcius all the time. Or there maybe a wire that is run to connector C220 pin B and you can ground it there. Not sure where this connector is as I can't find the reference, but typically if the car was equipped with Daytime Running Lights, it would have this pin grounded, hope this helps.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
