diff/gears - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 05-26-2013, 10:58 AM Thread Starter
diff/gears
I just bought a complete diff from a 1993 caprice 9c1/w 3.42, but it need a clutch pack, so can i swap everything i need from my 2.56 g80 in the 3.42?
thanks
d-666 is offline
post #2 of 7 (permalink) Old 05-26-2013, 09:16 PM
If the rears are the same size, you can swap them, but you will have to set your gear mesh. You can not just bolt the parts in.
post #3 of 7 (permalink) Old 05-27-2013, 08:20 PM Thread Starter
Not sure if the clutch pack from 2.56 will fit with 3.42?
If I'm not mistaken, 2.56 is Series 2, and 3.42 is Series 3, which MAY mean that a Series 2 clutch pack won't fit in a Series 3 gear set?
That'd be my issue of concern.
That's what i tought, if the series 2 stuff can fit a series 3?
d-666 is offline
post #4 of 7 (permalink) Old 05-27-2013, 11:25 PM
MillerTimeGS's Avatar
Only 2.93 and numerically larger work together. 2.56 carrier won't accept standard used 3.42. You can buy gears spaced that way though.
Sent from AutoGuide.com App
MillerTimeGS is offline
post #5 of 7 (permalink) Old 06-12-2013, 01:33 AM
MrBuick (Magnum)'s Avatar
Send a message via AIM to MrBuick (Magnum)
2.73 and "lower" were a series III carrier. 2.56 and "Higher" was a Series II. A series II carrier could be used with a series III gear set if you had a spacer ring. I don't know that they still make them or not. Easier just to find a good used posi.
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS. 14.21 at 91.79 "Jesus", Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.12 Buffman's car, Cracked Piston at 180k
96 DGGM Buick RMW 263k Stock Tranny
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons. Fried #7 Ring.
And 5 other LT1 B-body's... Is there Rehab for this Sh*t?
MrBuick (Magnum) is offline
post #6 of 7 (permalink) Old 06-12-2013, 11:42 AM
2.56 is Series II from an 8.5" axle.
2.93, 3.08, 3.23, 3.42, 3.73, 4.10, etc are all Series III from an 8.5".
2.73? No idea if it's Series II or Series III, but it's from a 7.625" axle.
Anything under 3.23 should not even be considered, and only if it originally came with 2.56 or 2.73.
If it originally came with 2.93 or 3.08, you WILL NOT notice 3.23, you might not really notice 3.42, and you might regret not going to 3.73 - even with all the cautions I insist on mentioning about HiWay MpG and the $400 it MIGHT cost to stop your driveshaft impersonating a guitar string.
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
post #7 of 7 (permalink) Old 07-06-2013, 09:23 PM Thread Starter
that'S what i've done , found a 3.42 posi (complete diff) and swapped the whole thing today..feel like a different car..very happy with it..the best part is i pais 80$ for the diff, complete with brakes and all
d-666 is offline
