LT1 cam swap, does it require a ECM/PCM programming ? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 09-14-2013, 09:17 AM Thread Starter
Ive been considering doing a head and cam swap on my lt1 rms, what i want to know is do i have to get the ecm/pcm reprogrammed to accept the bigger cam lift which will result in a different idle or will the computer compensate for the changes automatically ?
theGAME519 is offline
post #2 of 3 (permalink) Old 09-14-2013, 08:51 PM
The computers are not self learning. You have to reprogram it, or have it reprogramed.
post #3 of 3 (permalink) Old 09-15-2013, 12:07 PM
BCs71's Avatar
Ditto. It's required in the least to actually get the benefit of the cam swap, but also depending on the cam you choose, maybe prevent damage.
Be sure to look into new valve springs when/if you do a cam. Stock springs are marginal, at best, and will make a new, higher-revving cam fall flat.
1996 Caprice LT1 DGGM B4U, mostly stock daily driver
1996 Caddy Fleetwood Brougham, wife's new grocery getter
1994 Caddy Fleetwood Brougham, lots of show & a little go
1992 Caprice wagon, L05, posi, factory no wood - wife's grocery getter
B.a.D. Bodies of Chicago, RIP
BCs71 is offline
