Fuel pump question - Chevy Impala SS Forum
post #1 of 27 (permalink) Old 09-20-2013, 09:55 PM Thread Starter
ocala's Avatar
Fuel pump question
Hello all,
My Roadmaster has always been a little slow to start. The car has only 60K miles and runs great otherwise.
I recently put in a new starter, so now the engine turns over quickly, which it didn't do before.
Still, I have noticed occasionally that even though the engine is turning over quickly, the car wouldn't always start right away. I have NEVER smelled gas when this happened.
Other times, the car would start very weakly, sputter and almost die. I would coax it to higher RPMs. Usually once it got going it would keep running.
More recently, it wouldn't start at all until after a few tries. This would happen anytime, but most often after the car had been driven on a hot day and was still warm. Again, NEVER a smell of fuel. All the symptoms of no fuel.
So TODAY, I was driving along just after filling the tank (%^#^^*!!!) it burped and died. I tried many times to start it with no luck. Kicked a few times but that was it. I was ready to call AAA. (I think a AAA membership is a great thing when you daily drive a B-body!)
A guy nearby who was smarter than me got under the car while I turned on the ignition and said he couldn't hear the pump. I tried listening for it from inside the car before he showed up and I couldn't hear it either.
He suggested that he beat on the underside if the fuel tank while I tried starting the car. Started right up.
So here I am. The car has started a few times since at my house with no problem. I think I should replace the fuel pump so I don't get left somewhere else. The problem is intermittent, so I'm thinking checking the fuel pressure while running won't help.
I got under the car while a friend turned on the ignition at my house. Now I CAN hear the pump, but it doesn't sound really healthy. By this I mean weak compared to my impala, which I can hear easily from inside the car.
Of course I'm going to replace the filter while I'm at it.
Am I right, or am I missing something? Should I just put in a new pump?
Thanks
Sent from AutoGuide.com App
ocala is offline
post #2 of 27 (permalink) Old 09-20-2013, 10:07 PM
Fuel pump question
Many times they do behave this way,when they're (fuel-pumps) on the way out. Sometimes,they'll work for a while. Usually,the clock is ticking.
post #3 of 27 (permalink) Old 09-20-2013, 10:10 PM Thread Starter
ocala's Avatar
Thanks!
That's enough for me. I can't think of a better place or time to change the fuel pump than in MY garage on a weekend.
ocala is offline
post #4 of 27 (permalink) Old 09-20-2013, 11:42 PM
Sinister SS's Avatar
Send a message via AIM to Sinister SS
Changing a fuel pump on these cars is easy. Consider updating with a Walbro 255 and new in tank pump harness.
BV
Used to have....
96Impala BBB, .600 lift cam, Crane 1.5 RR\'s, Crane dual springs, Accel SupeRam intake extrune honed/ceramic coated...a bunch of other stuff..BV Performance anti sway bars and OBD2 tuning.
now...
Sinister SS is offline
post #5 of 27 (permalink) Old 09-20-2013, 11:56 PM Thread Starter
ocala's Avatar
I'll definitely do that on the impala, but this Roadmaster I'm thinking to keep mostly stock.
Can I get a performance improvement from this with no other mods?
I do have a set of SS wheels for it as soon as I wear out the tires on the stock wheels...
ocala is offline
post #6 of 27 (permalink) Old 09-21-2013, 12:31 AM
coltonx3's Avatar
Fuel punp is on its way out and check the harnnes at the pump to I bet its burnt
95 9c1 dggm
straight black pvc kn filter
spintech pro street mufflers
most of trim and grill painted black
150k running strong and going
coltonx3 is offline
post #7 of 27 (permalink) Old 09-21-2013, 12:49 AM Thread Starter
ocala's Avatar
Will do thanks.
ocala is offline
post #8 of 27 (permalink) Old 09-21-2013, 06:19 AM
The Fooser Guy's Avatar
Wink THIS will help...
To save a lot of aggravation, read this: http://www.grail-ss.com/FuelTankPumpGUIDE.htm
- particularly the last part. (Okay, it's mine - but it it helps.)
The Fooser Guy
The Fooser Guy is offline
post #9 of 27 (permalink) Old 09-22-2013, 10:44 AM Thread Starter
ocala's Avatar
Thanks EVERYONE for the help!
The fuel pump is in, and I can definitely see a difference in how the car starts.
The advise provided by you all made this job much easier.
ocala is offline
post #10 of 27 (permalink) Old 09-22-2013, 09:31 PM
hooligan's Avatar
hopefully you replaced the in tank harness, or be prepared to do the job over again soon.
9 times out of 10, the harness is the reason for the failure.
96 RMS Limited
hooligan is offline
