roadmaster rear wheels question - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 02-06-2014, 11:07 PM Thread Starter
miahgiven's Avatar
hey guys i was wondering if i could run a 17x8 rim with a 4in backspace on a roadmaster sedan and clear the fenders... if it helps i would be running a 235 55 17 on the 17x8s.. looking into better rims than my 15 inch steelies when i get my tax return... thanks guys
Originally Posted by Blue Wail View Post
No downside to any stroker; you will pass everything except a gas station!!!
Nab
miahgiven is offline
post #2 of 7 (permalink) Old 02-06-2014, 11:36 PM
You should be safe with that size. The wheels will be about 1/2 in further out, but you can use 9 1/2 inch rims with the OEM offset and still not hit, so you should still have about a half inch or so of clearance.
To find out what the OEM offset is, measure the original rims, and you may even get a little closer. I believe the original offset is -6mm.
post #3 of 7 (permalink) Old 02-07-2014, 10:29 PM Thread Starter
miahgiven's Avatar
i was worried because i had 235 75r15s on 15x8 truck rallies and i had rub so i had to switch back to the 15x7s...:/
Nab
post #4 of 7 (permalink) Old 02-07-2014, 11:19 PM
Your truck rims probably do not have enough offset to the outside.
post #5 of 7 (permalink) Old 02-08-2014, 07:29 AM
Wagon rear wheels
I am running 15 x 8 truck rally's with 255 60 15 tires with no rubbing at all.
TheAndyMan is offline
post #6 of 7 (permalink) Old 02-13-2014, 11:14 PM Thread Starter
miahgiven's Avatar
i was so confused because they fit perfectly when i had the stock 235 70 15s but not the 235 75 15s....
Nab
post #7 of 7 (permalink) Old 02-17-2014, 03:35 PM
Brokecello's Avatar
If it rubs just on one side...it's prob your axle not being centered. (each car is a little different)
You can also (cringe I know) use a grinder and take out some of the lip edge...just be sure to clean and paint it well when you are finished.
I had to do that on an OCC I had. Even after I tried centering the axle it would still rub a little in a turn. Took some of that fender lip off and it was good as gold.
Chris
* 1995 Jadestone Limited RMW <--- Click For Pics
CarISSMA Club Member / ISSCA #2027
Brokecello is offline
