9C1 rear end installed - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 04-10-2014, 06:35 PM Thread Starter
I recently had my 9C1 rear end installed in my 95 RMS.
Southern Gear did the rebuild.
Kevin Elliot and John McRae did the install.
PCM4Less reprogrammed the computer.
I did all the paint and Project Management.
3:08 gears
Auburn HD Limited Slip
All New Guts
Its a daily driver...I have 3:73's in my wagon!!!
Name:	2014-03-31 16.06.23.jpg
Name:	2014-03-31 16.08.01.jpg
Name:	2014-03-31 16.12.40.jpg
Name:	2014-03-31 16.13.29.jpg
Name:	2014-03-31 16.09.14.jpg
B BOdY is offline
post #2 of 12 (permalink) Old 04-10-2014, 10:27 PM
AZ Roadmaster's Avatar
Nice!!!!!!!
[/SIGPIC]92 RMS, daily driver, project car, Eibach springs, Bilstein shocks, BMR rear upper and lower control arms, BMR front and rear sway bars, Dick Miller braces, Spohn spherical ft end links, fabricated ft sway frame support, ROH wheels with Nitto tires, replaced upper and lower control arms and all steering linkages and reman box. reprogramed ecu, tb spacer, adj. fp reg, cold air intake, electric fans, pully kit, SS rear with posi 3:73's Next big brake kit!
AZ Roadmaster is offline
post #3 of 12 (permalink) Old 04-12-2014, 10:40 PM Thread Starter
A little over 300 miles on it... leaving work tonite, some dick in a nissan had something to say at the red light..... Later dude!!!
It was either 350, or 9mm... I gave him the gas.....
Ahhhh!!! cant wait to put the 383 in my wagon!!!
Name:	2013-01-22 15.33.09.jpg
B BOdY is offline
post #4 of 12 (permalink) Old 05-07-2014, 08:06 PM Thread Starter
Had the fluid changed at 500 miles....what a difference!!!
B BOdY is offline
post #5 of 12 (permalink) Old 05-07-2014, 11:33 PM
Dropped Fullsize's Avatar
Very nice!!! Great job.
I installed a 9C1 rear end on my SS a little over a year ago. Did 373 gears, Eaton posi, powder coated rear end, Moser axles. Tuned by PCM for less etc..
One of my better mods. Better wheel to body clearance too.
Dropped Fullsize
82 El Camino
95 Impala
00 Crew Cab Chevy Dually
01 300M
02 Silverado
11 Crew Cab Silverado
_______________________________________________
Dropped Fullsize is offline
post #6 of 12 (permalink) Old 05-14-2014, 03:32 PM Thread Starter
Interesting, you must be using wider than stock wheels and tires on your SS...
B BOdY is offline
post #7 of 12 (permalink) Old 05-14-2014, 05:49 PM
Moderator
Goldmaster's Avatar
The 9C1 rear end is slightly shorter than the SS. I have also done this mod in the past
Goldmaster is offline
post #8 of 12 (permalink) Old 05-22-2014, 08:49 AM Thread Starter
Godzilla!!!!
Name:	2013-04-17 15.54.39.jpg
Name:	2013-04-17 15.54.17.jpg
B BOdY is offline
post #9 of 12 (permalink) Old 07-02-2014, 07:50 AM
Are you happy with the 3.08s or do you wish you went steeper? Trashing the 2.56s is on my list of things to do to my RMS
'94 Roadmaster Sedan
ADub is offline
post #10 of 12 (permalink) Old 07-15-2014, 10:53 AM Thread Starter
my wagon has 373's, which is a bit much, the sedan is a daily driver. 308's are perfect.
B BOdY is offline
