RMS orange running lights questions - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 04-28-2014, 04:43 PM Thread Starter
Lowrizza's Avatar
Hey guys I did some searching in the main forum electrical/lighting sections but couldn't find the 2 pieces of info I need:
1) How to replace a bad bulb in that orange strip (running lights?) under the Roadmaster Sedan headlights?
2) What's the bulb type?
The factory service manual does not have a good diagram of the RMS headlight assembly. I'm guessing you have to pull the whole headlight assembly out to access the 3 bulbs in the orange strip below it and they're "194" bulbs...but..
I thought I'd ask around before I start taking stuff apart.
Thanks.
-Rizza
'96 RMS Electric fans w/Gary's harness PCM4Less LT4 knock module 160deg 'stat TB bypass H-pipe & Resonator delete K&N intake 17" wheels Freeze-bleed AC-drip hose Braided brake lines 9C1 front calipers Deep trans pan Non-power antenna Window tint & Roller fix HID headlights LED interior lights Gas gauge fix BMR rear upper+lower control arms front+rear sway bars Belltech drop shocks&springs 5/8" ball-joints DMR/Buick frame braces 'Vet starter Crappy stereo AIR delete
Lowrizza is offline
post #2 of 5 (permalink) Old 04-30-2014, 11:57 PM
heavybuick's Avatar
I had a problem with one of the bulbs a couple years ago. At the moment, I can't recall exactly what I did to accessed the bulbs but, I know that I did not remove the entire headlamp. I was able to pull that section of lights out enough to fix the bulb.
1994 Buick RMS Limited
heavybuick is offline
post #3 of 5 (permalink) Old 05-01-2014, 07:49 AM Thread Starter
Lowrizza's Avatar
Excellent.
Thank you very much for taking time to reply.
-rizza
Lowrizza is offline
post #4 of 5 (permalink) Old 05-01-2014, 08:15 AM
There is a small torx screw at the inside (toward the center of the car) of the mount. If you remove it, the fixture can be rotated out.
post #5 of 5 (permalink) Old 05-04-2014, 06:21 PM Thread Starter
Lowrizza's Avatar
Thank you for the help guys
Thanks guys, the "rotating " part was critical info. I really had to muscle mine and it was less nerve wracking, knowing that's how they're supposed to come off. The metal clips that secured the light to the body panel were rusty and I think that made them harder to remove.
-rizza
Lowrizza is offline
