Long cranks in the morning - Page 3 - Chevy Impala SS Forum
 1Likes
post #21 of 30 (permalink) Old 06-20-2018, 03:31 PM Thread Starter
HUF
HUF's Avatar
Originally Posted by BALLSS View Post
the strainer should come with the pump assembly...but you can buy them separate for a few $
RA has the Spectra for $89
https://www.rockauto.com/en/moreinfo...027404&jsn=418
...and the Delphi for $218
https://www.rockauto.com/en/moreinfo...027404&jsn=419
if given a choice I would use Delphi....but there is a considerable price difference...but you do often get what you pay for
I carefully pried off the original strainer and snapped it on new Spectra pump. Everything is back in tank and ready to be placed back on the car.
The original pump had discoloration (dark) around negative side, but the wires are fine. Will post pictures later. Have to finish the job before it rains!
Okay. The new pump is in and everything seems to be fine. The FPR works as it was supposed to do, so it was not the problem. The problem was the original fuel pump, which overheated internally and caused discoloration of the plastic.
There’s nothing as permanent as a temporary solution.
1995 Cadillac Fleetwood Brougham 122,XXX miles.
HUF is offline
post #22 of 30 (permalink) Old 06-20-2018, 06:11 PM Thread Starter
HUF
HUF's Avatar
Here is the original pump. 123,000 miles 22 years old.
Name:	IMG_2816 - Edited.jpg
HUF is offline
post #23 of 30 (permalink) Old 06-22-2018, 11:17 AM Thread Starter
HUF
HUF's Avatar
The pump I have replaced had that rubber on it just as it is shown in the picture. So, I took it off and put on the new Spectra pump.
I am curious, what are those two other rubber parts for? One looks like a piece of hose and the other is a smaller part, which looks like a rubber retainer/spacer with complex geometry. Thanks.
Name:	Screenshot 2018-06-22 at 12.15.01.jpg
HUF is offline
post #24 of 30 (permalink) Old 04-08-2019, 11:47 PM Thread Starter
HUF
HUF's Avatar
Well, seven months and 1,400 months later I had a no start condition (only cranking). Unfortunately, could not check the spark, fuel pressure, etc. right away. Next morning, the car started right away and fuel pressure was within specs. Parked the car for months. Was afraid to drive without knowing what caused no start.
Will be driving only to make the car act up again and have the opportunity to test spark, fuel pressure, etc when it happens again. Nevertheless, I have a question. Did anybody have a bad luck with Spectra pump AND housing assembly, not just a Spectra pump. I suspect the old wiring is the problem I am having. The negative wire going to the pump was quite fried , but the connector itself looked fine.
BTW, if anybody want to see the original ACDelco pump dissected here are some pictures.
HUF is offline
post #25 of 30 (permalink) Old 04-09-2019, 06:09 AM
Originally Posted by HUF View Post
....I had a no start condition (only cranking). ......Next morning, the car started right away and fuel pressure was within specs.
Sounds like temperature changed enough or you jostled things enough to re-establish pump connection(s). It could be loose wiring on IC/ICM ????
...... I have a question. Did anybody have a bad luck with Spectra pump AND housing assembly, not just a Spectra pump. I suspect the old wiring is the problem I am having.
Never had trouble with the replacement Spectra, but had to drop the tank again 1 month afterward to tighten up the lug on one connection. No issues in 5 years since
So was one of the connections on mine. Insulation was burnt completely off the end 1 1/2".
Carry a pc. of 2x4 and wack the tank next time a no-start to confirm if just a loose connection. I didn't read whole thread. Did you install all-new harness, sender? I recall something about a bigger-wire upgrade harness ?Airtex?
post #26 of 30 (permalink) Old 04-09-2019, 12:31 PM Thread Starter
HUF
HUF's Avatar
96Black,
Thank you for your advice. No, I did not put a new wiring harness. A big mistake, I guess.
Because Spectra fuel pump, sending unit assembly (the whole thing) is under $100, I am thinking of buying one. I think all negativity about Spectra pumps is mostly because of not installing new harness while replacing the old pump.
HUF is offline
post #27 of 30 (permalink) Old 04-09-2019, 06:47 PM Thread Starter
HUF
HUF's Avatar
Today, I idled the engine for 60 minutes to make the fuel pump/wiring or whatever else was the culprit to overheat and cause no start condition, but car UNFORTUNATELY (!) started again and again and again... The fuel pressure was within specs.
HUF is offline
post #28 of 30 (permalink) Old 04-09-2019, 06:57 PM
Long cranks only in the morning. Checked fuel pressure and found it between 20 psi and 28 psi primed. The key on/off trick helped a bit. What really surprised me (unpleasantly) the idle pressure was 35 psi with AND without FPR. The gauge needle was fluttering. The vacuum at the FPR port was 18". It used to be 20". No signs of fuel in FPR port. It used to be 44 psi with vacuum removed from FPR. Do you think the FPR is shot or maybe vacuum is too low to make it work?
Checked vacuum at the optispark vent and it was 15" (used to be 18").
I have a replacement fuel pump but it looks as soon as one replaces the original pump, one keeps replacing them again and again...
OMG i had the same troubles last year, turned out being the aftermarket fuel pump their all made in china and are crap! I was told about this website that sells all O.E. gm parts for cheap i ended up trying them and my fuel pump issues are no more so try a o.e. part it worked for me. check out www.gmpartsprime.com i would suggest them to any one.
Impalapro is offline
post #29 of 30 (permalink) Old 04-09-2019, 07:00 PM Thread Starter
HUF
HUF's Avatar
Impalapro,
Thank you, but that was the original (GM) fuel pump with 122,000 miles on it.
The price for the same ACDelco fuel pump at the site you recommended is 1.5 times the one at Amazon. I'll stick with Amazon.
https://www.gmpartsprime.com/oem/cad...-25163464.html
https://www.amazon.com/dp/B000C9QNZU...v_ov_lig_dp_it
HUF is offline
post #30 of 30 (permalink) Old 04-09-2019, 07:45 PM
gbhs72's Avatar
Yeah I think all Y'all may be right.
Mark: Snowman-33
gbhs72 is online now
