Extended crank only below 40 degrees - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 12-04-2018, 05:12 PM Thread Starter
New battery and 40 pounds of fuel pressure when priming. Starts immediately if external temperature is above 40ish. At 30 degrees cranks and cranks before starting.
rodder4hire is offline
post #2 of 11 (permalink) Old 12-05-2018, 03:08 PM Thread Starter
Anybody got anything on this?
post #3 of 11 (permalink) Old 12-05-2018, 05:33 PM
Component or connection contracting enough to open or short? Check grounds, relays. Check for signs of molested abraded squished cut wiring, buggered connector ends. Get a friend when well below that temp and be prepared to wiggle The Crap outta everything you can think of under the hood to see if it makes it catch quicker/immediately while he/she cranks.
EDIT: Interesting that it's tied to freezing water temp. If the Elec Temp Sensor is implicated in starting/running it may be weak and ready to replace? Probably a way to do VOM checks at diff temps to confirm?
96 Black is online now
post #4 of 11 (permalink) Old 12-06-2018, 09:24 AM
Banned
I just had this issue ,,,,, battery was weak .. engine cranked slightly slower but it did not start... I got voltmeter out and I checked the volts at the fuel pump connector .. when I cranked the engine the volts dropped to 8DC so I put a trickle charger on it , and the next day and after it cranked only 1/10th of a sec and engine started up perfectly ..
new battery or connections can be bad .. new battery maybe sitting on shelve too log ..
j cat is offline
post #5 of 11 (permalink) Old 12-06-2018, 09:27 AM
Banned
key on , eng off not cranking 41PSI and less sure can be the battery when cold out ..
j cat is offline
post #6 of 11 (permalink) Old 12-07-2018, 01:38 PM
How long has it been since the last time the car was started?
Is the car also cold, or is it still warmed up - or does it start the same regardless?
They are NOT Lying to You
You are Not Lying to Yourself
… Alone
1g1bl82p7rr127841 … RIP,IP …
Marky Dissod is offline
post #7 of 11 (permalink) Old 12-07-2018, 09:07 PM
HUF
HUF's Avatar
There could be a reason old batter went bad. The same reason still can be there and affect the new battery.
There’s nothing as permanent as a temporary solution.
1995 Cadillac Fleetwood Brougham 122,XXX miles.
HUF is offline
post #8 of 11 (permalink) Old 12-11-2018, 04:22 PM
I agree with other suggestions. Check battery, grounds, etc. If it cranks and cranks strong but does not fire... First you have to confirm you have spark and fuel. Spark can be confirmed easily by shooting some starting fluid in the throttle body. If it starts then dies, then it's not spark but fuel. If fuel pressure is good, then I'd take a look at the IAC. Might be stuck or sluggish. Normally I'd use a scan tool to watch the IAC. Can't remember how to test it without one.
storm9c1 is offline
post #9 of 11 (permalink) Old 02-28-2019, 10:00 AM
Hey coming up on 2 months and the majority of temps here have been BELOW 40. IDK where you are, but what did you find rodder-?
post #10 of 11 (permalink) Old 03-01-2019, 08:52 AM
Banned
I agree he should post how he resolved this issue ?
j cat is offline
