1996 Chevy Impala ss won't stop overheating - Chevy Impala SS Forum
post #1 of 8 (permalink) Old Yesterday, 03:42 PM Thread Starter
Jusailakes's Avatar
Hello to my favorite forum and forum people. Again here I am asking all yall to advise me . I've changed the thermastat,new plugs and wires (if that would effect it)distributor cap and constantly check my antifreeze and keep it full.Yet my 96 takes no time to get hot(the needle to the middle and sometimes further past). I'm not going far or driving long at all and it starts getting hot.Any ideas?
Jusailakes is offline
post #2 of 8 (permalink) Old Yesterday, 04:31 PM
With just what you typed I'm going with you did not reinstall WP drive coupling after doing the [quote] I've changed the .......... distributor cap .........
others:
blown h. gasket
infamous clay pellets finally sealed the flow
Or, simply did not burp sufficiently/properly.
Ques: Are you losing AF? If so, then mayhaps break in system and not maintaining pressure
Or, as simple as a sacked out cap.
Probability of each above depends on the actual duration of "takes no time to get hot"
post #3 of 8 (permalink) Old Yesterday, 04:40 PM
I'm going to guess its an air-bubble.
atlantadan is offline
post #4 of 8 (permalink) Old Yesterday, 05:46 PM
OP
did you bleed the cooling system after you changed the thermostat?
the gen 2 LT1 is a reverse cooling motor, opposite all other SBC, and you need to bleed the air from cooling system if you open it up like by changing T stat, WP or hoses.
post #5 of 8 (permalink) Old Yesterday, 11:40 PM
babywag's Avatar
Are the fans working?
babywag is offline
post #6 of 8 (permalink) Old Today, 07:17 AM
Hi
What makes you think that its overheating,is steam coming out? The temp gauge in the middle is not to hot. These cars normal running temp is 230 degrees. The fan should come on around 227 and the second fan about 232. Oldhead
95 WAGON.SS wheels,Exhaust straight out the back.Extra bright cargo lights.Virgin ashtrays,Copper battery term.32# in tires
oldhead is offline
post #7 of 8 (permalink) Old Today, 09:09 AM
Yah Oldhead - sure 1/2 is not officially overheated. But mine "almost always" stays under 1/4 except the rare occasion of real hot out and long crawling traffic. So anything out of the usual is noteworthy. Let's see how many boxes the OP can check off with all the replies so far.
post #8 of 8 (permalink) Old Today, 01:34 PM
juniorwatson's Avatar
This is where it's at. First I like to get the OP's definition of overheating, and if it's that the guage get's to almost 1/2 way, then this is a moot point.
I've got a mechanical gauge in the cylinder head, and my PCM & cluster temp coming from the F-Body sender in the water pump.
1/2 on the cluster gauge is somewhere around 190-200'F. My car runs that temperature all the time in city driving.
juniorwatson is online now
Similar Threads
1996 502 Impala SS Overheating Issues 502-SS Heating/Cooling/HVAC 27 09-02-2012 03:39 PM
Overheating problem: fans are on but car is still overheating PrinceofSP215 Engine Problems/Maintenance 5 03-24-2011 03:01 AM
voltage drops when i stop at a light/stop sign and car stutters, then back to normal? 1996caprice9c1 Engine Problems/Maintenance 13 08-14-2005 03:48 PM
help!!!! my car wont stop overheating russ Engine Problems/Maintenance 4 06-24-2002 05:11 PM
