Rebuilt PS pump missing high side casting - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 04-20-2019, 06:24 PM Thread Starter
How do you swap the pressure side connection casting? Note the old one in the foreground. There's no thread in the new pump - so is that supposed to be pressed out and in? Read a bunch of threads on ps pump replacement and noone mentioned this little conundrum.
Note: This is for my 96 fwb.
\'89 Boxy w spot - Belton Missouri 9C1 / RIP
\'95 White NCSHP 9C1 - RRs, a hockey puck, summit turbos and a Herter tune.
\'96 DGGM L99 - only driven to Church on Sundays \"[Smile]\"
'96 TripleBlack Fleet - On Impy rims and ASA Monoblok 19x8.5 w pirelli 245/45
James H.
imported_Eracer is offline
post #2 of 8 (permalink) Old 04-20-2019, 08:28 PM
babywag's Avatar
You sure there isn't just a plug stuck in the hole from when they painted it?
babywag is offline
post #3 of 8 (permalink) Old 04-20-2019, 08:47 PM Thread Starter
Take a close look. The old pump in foreground has fluid pressure output bung and pressure sensor connector. The circa 2015 reman which I've had on the shelf has nothing but a smooth bore. It looks like that piece needs to be pressed on off and on.
Edit: now i'm thinking just another ****ed up reman where they forgot to press on the bung/casting pressure side casting.
Edit2: and if you could think they would **** it up in mexico, it's no surprise they would **** it up even more in china with the cardone garbage. This is a sad state of affairs.
James H.
post #4 of 8 (permalink) Old 04-20-2019, 09:14 PM
babywag's Avatar
Can't take close look your pic doesn't show reman. and too small/bad angle.
All pumps I've had they simply unscrew.
babywag is offline
post #5 of 8 (permalink) Old 04-21-2019, 07:41 AM Thread Starter
Thanks for weighing in babywag. This is perplexing to me, no threads inside reman casting.
Edit: Ah, I pulled the piston and spring out to reveal the threads. Question: Do I pull the C-clips off the end before unbolting the casting?
Thx in advance!
James H.
post #6 of 8 (permalink) Old 04-21-2019, 09:23 AM
babywag's Avatar
Hard to tell from pic but it looks like some form of plug in there. Very odd. If it was me I'd try to see if I could remove it.
babywag is offline
post #7 of 8 (permalink) Old 04-21-2019, 12:56 PM Thread Starter
Yep, that's the plunger and spring which I didn't realize comes out. Last pic I turned it over and it fell out, revealing the threads within. I let it sit on the ps on the past pic for reference.
Thanks for your help. It's always nice to have someone look at something with a different set of eyes.
James H.
post #8 of 8 (permalink) Old 04-21-2019, 02:16 PM
babywag's Avatar
glad you figured it out...odd that those were in there but not line fitting/casting.
babywag is offline
Similar Threads
front end rebuilt now front sets high <<1 of 1>> Suspension 10 05-14-2013 08:44 AM
Water Pump Casting Numbers and Letters bkh Heating/Cooling/HVAC 0 08-25-2011 06:52 PM
PS Pump #5 is acting up - Ordering a Tom Lee box and pump on Monday! scoob8000 Suspension 38 06-24-2007 10:56 AM
95 4L60E rebuilt . . . now vibrates in 4th especially at high speed!! ratchetmaster Drivetrain 17 02-23-2007 08:03 AM
Rebuilt Engine Missing tlpierce Engine Problems/Maintenance 3 04-20-2006 12:55 PM
