Slight miss - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 05-19-2019, 06:58 PM Thread Starter
Josh577's Avatar
Slight miss
What’s up guys it’s been a while. So I’ve talked about my impala on here more than once, I always seem to get pretty good advice on here. This car has had every changeable component replaced on it Front to back and Looking back now I see that was a mistake! I took a lot of good GM parts off and replace them with O’Reilly’s crap!
I think I’ve almost replaced every component again from failure. The problem I’m having now is I’ve noticed a loss of power, low end power. When I’m driving there’s an occasional slight miss, just like a loss of spark just for a brief second the motor cuts out out.
it does it every so often as I’m driving but it’s becoming more frequent. I changed the opti last year to an accel brand
I was told that was a good one, now the plugs and wires were nothing great they were just O’Reilly’s crap. What do you guys think? do you think it could just be plugs and wires
Josh577 is offline
post #2 of 8 (permalink) Old 05-19-2019, 09:10 PM
4x4high's Avatar
Originally Posted by Josh577 View Post
Whatís up guys itís been a while. So Iíve talked about my impala on here more than once, I always seem to get pretty good advice on here. This car has had every changeable component replaced on it Front to back and Looking back now I see that was a mistake! I took a lot of good GM parts off and replace them with OíReillyís crap!
I think Iíve almost replaced every component again from failure. The problem Iím having now is Iíve noticed a loss of power, low end power. When Iím driving thereís an occasional slight miss, just like a loss of spark just for a brief second the motor cuts out out.
it does it every so often as Iím driving but itís becoming more frequent. I changed the opti last year to an accel brand
I was told that was a good one, now the plugs and wires were nothing great they were just OíReillyís crap. What do you guys think? do you think it could just be plugs and wires
It could be just about anything. What year is the car? I would start by putting a scanner on it to see what cylinder(s) are misfiring and then go from there.
Have you checked your fuel pressure yet?
1996 DGGM Impala SS
4x4high is offline
post #3 of 8 (permalink) Old 05-19-2019, 09:36 PM Thread Starter
Josh577's Avatar
No none of the above yet. The car is a 96 and of now there’s no engine lights. I did take off the smog pump recently and I didn’t have it tuned after. I’m not a good mechanic, amateur part changer at best.
Josh577 is offline
post #4 of 8 (permalink) Old 05-19-2019, 09:50 PM
4x4high's Avatar
No none of the above yet. The car is a 96 and of now thereís no engine lights. I did take off the smog pump recently and I didnít have it tuned after. Iím not a good mechanic, amateur part changer at best.
Did you change the knock sensors by chance?
1996 DGGM Impala SS
4x4high is offline
post #5 of 8 (permalink) Old 05-19-2019, 09:50 PM Thread Starter
Josh577's Avatar
No I never have, never thought to
Josh577 is offline
post #6 of 8 (permalink) Old 05-20-2019, 08:51 AM
.....I took a lot of good GM parts off and replace them with OíReillyís crap!
If you kept the old parts then possible to re-install (maybe one at a time) to gauge any improvement/cure.
Not understood. You re-replaced all the new parts that you just installed because almost all of them have failed?
One
Two
Three. Separately and together all good reasons to check stickies and threads by searching 'Off-idle Stumble'
I changed the opti last year to an accel brand I was told that was a good one,
Who told you it was 'a good one'? Any aftermarket opti is a crap-shoot regardless of brand, some luckily assembled well, the next one on the line is a mess. Others with poor quality components last a while then not. There's a couple recent threads on pulling electrical diagnosis with a meter, and you can always pay a shop to hook up and read the motor. Search the opti re-build threads on 1.)frequent things found to fail (weak cap, missing seals, loosened rotors), and 2.) how to blueprint it with all the items to attend to and make it more reliable. Grease and locktite are involved.
now the plugs and wires were nothing great they were just OíReillyís crap. ...do you think it could just be plugs and wires
Not understood. Did you replace the plugs/wires or not? If so, did you make sure all plugs clicked twice both ends? Are any wires damaged from touching something hot?
The act of replacing a lot of parts can cause issues with pulled/broke hoses/wires. Several recent threads describing to use carb cleaner/ether to check for intake/vacuum leaks.
post #7 of 8 (permalink) Old 05-20-2019, 09:51 AM Thread Starter
Josh577's Avatar
I did use propane and checked vacuum leaks recently, fixed a lot of them but I could re-check it again
Josh577 is offline
post #8 of 8 (permalink) Old 05-20-2019, 11:35 AM Thread Starter
Josh577's Avatar
Yes. I did replace plugs and wires.
Yes. most of the part I put on the car last year have gone bad.
No. I didn’t keep the old parts.
I watched a video on YouTube that said the opti I got was a good brand.
As far as reading the sticky’s, well I don’t know if it’s just on my end or it happens to every one that visits this site, but I can’t do any thing on this site more thin two minutes with out a spin to win pop up coming up.
It takes me completely off this page when it happens, I can’t get it to close out or go back, after about ten seconds it sets security warnings off on my phone.
I end up having to close out every thing and start over. retype the site up, log back in and I might get five minutes before it happens again.
Josh577 is offline
Similar Threads
very slight miss at cruising speed 386kustoms Engine Problems/Maintenance 18 10-12-2010 09:02 PM
Complete Tune Up still have a slight miss at idle BrandonG777 Engine Problems/Maintenance 13 10-04-2010 04:25 PM
slight miss tedstech Engine Problems/Maintenance 1 06-11-2008 02:36 PM
Slight miss at idle in the rain. k3000-a Engine Problems/Maintenance 3 04-13-2008 04:42 PM
Slight hesitation/slight surge Narti Engine Problems/Maintenance 0 04-15-2002 01:19 PM
