Hey guys, a little more than a month ago I posted about a problem I am having with my 96SS. I did not get it fixed before I left for tour but I am back at it now and still need some help. Heres the details....
Fuel Pump intermittently cuts off/on
Replaced Sending Unit, Fuel Pump, and Fuel Filter, still same issue.
Fuel pressure is steady at 40psi
Connected the bypass connector next to the fuse box under the hood to + power and it does make the Fuel Pump run continuously.
Metered the Relay, has 12V
Metered the Fuel Pump connector black and grey wires and got 12V.
Car will start and run for a little bit after several times of it intermittently priming itself, so I know the engine will actually run.
I am at a loss here. Anyone have any suggestions on where to check next? It really seems like its a loose connector that is barely making connection somewhere.
Do you have a oil pressure gauge?..or has the "oil" light ever flickered?
IIRC when the OP sender senses 5 or less PSI it cuts fuel. The sensor could be bad if this is the case...or your have major issues with internal motor...but you would likely also be hearing a knock.
Then there is always the WTF happened because my car has been sitting and now something is not right.
is the 40 psi of FP with vacuum hooked to FPR? if without vacuum than 40 is low. Typically FP is 45-48 without vacuum and 36-40 with at idle with it increasing some as you increase rpm
I also have toured for decades and after being gone for several weeks or months a perfectly running car when I parked it is no longer happy about something. Frustrating
May be out there, but could it be you're misreading the symptom? Unless you're reading that current to the pump is actually breaking, then the so-called cutting off could be electrical. As in IC, ICM or opti (or its harness). On another note, I was out of the country an extended period and my black car was not acting at all right when I returned. I had good luck after - disconnecting batt a long time, and just doing a bunch of adjustments to make sure they were on. IAC, TPS, cleaned the EGR valve, sprayed the MAF, etc. It decided to run well again but I don't know what did it. It could have even been the double shot of Techron! lol
Now for the bad news. That new pump may have a non-steller connection with the harness. My new pump and harness and sender did. I got to drop the tank and redo the whole thing a second time just a couple weeks after the new parts.
I have not tried anything with the VATS. Its really acting like theres a connection thats loose and just barely making enough connection to come on and turn off again. This one sucks.
Hey, besides the ground right next to the battery and the grounds in the trunk on the angle pieces next to the trunk hinges, are there any other grounds I could/should check?
There's a connector on the left side of the trunk. Behind the carpeting, towards the top of the trunk. This connector feeds the brake lights, power to the fuel pump, and also the fuel level to the gauge cluster.
IDK why, but at some point my car would shut off if I stepped on the brakes, and the fuel level was always pegged at full. I unplugged that connector and cleaned all the contacts and it never happened again.
Try swapping the fuel pump relay with another relay? I had a buddy (not on the forums) just spend $$$$ on a new fuel pump and sending unit while on a trip only to have the same issue when he got home and discovered that the relay was going bad.
f6john, Yah, I also caught no mention of harness both above and in the original post. It's rather important to replace as all the rest while you're already in there. Airtex is favored as it has larger gauge wiring v. oem.
MattM, you got a head-scratcher fersur. Really getting interested in what the culprit turns out being.
Not the relay. The harness. It's just some wires and connectors. IDRecall now, but if it comes with the pump as an assembly then you're covered. --> But <-- as mentioned the Airtex harness is an oft-mentioned purchase to answer oem notoriously deficient gauge (thin enough to provide repeat pictures on here of the insulation burnt completely off).
No spark - BINGO. You have an ignition problem not a fuel problem if it holds 40 psi.
Start by replacing the coil and ignition module (ICM) as they are easiest.
If problem persists, replace the distributor (opti).
Key to helping the rest of us would be to know how you narrowed it the opti. Or was it just the next in line of a list of parts to replace to see what happens? Did you replace the entire assembly or just cap, rotor ect. Where , brand , of the parts you replaced . Thanks for sharing!
Sorry for basically a double post, my connection has been strange this morning. Anyway it does sound like it was throwing new parts at it till something worked,even though you were running tests and whatnot. I was hoping not to have to do that.
And how did you come to find that as the problem? That would be key info for those of us still trying to get our cars running without replacing a bunch of parts. I had my ICM tested as bad but a new ICM and new coil was not the answer.
Well, in the post there is a list of parts I replaced. And if you read my last post you'll see that the Opti got it up and running again. Therefore....that is how I came to the conclusion that it was the Opti that needed to be replaced. I could be wrong though...
That sounds like it comes under the heading of SWAG (Scientific Wild Ass Guess). Although, the symptom of happening when another system was activated leads one to commonalities, and making sure they are in good condition. Electricity is funny, if its ground route is disrupted, it often finds another path to ground. This can cause strange symptoms, or interactions with other systems.
Here's the LT1 Specialists check list for correcting a no-run condition:
In a no-run condition:
1. Always check fuel pressure first.
A. If none, jumper the test wire, check voltage at pump connection behind gas tank.
B. If voltage exists, replace the pump.
2. If fuel pressure is fine, check spark at coil.
3. if ok, check spark at spark plug.
4. If theres spark at coil but not at the plug, replace distributor (opti) as the rotor is probably broken or fell off.
5. If there's no spark at the coil, replace the coil and ignition module.
6. If #5 doesn't fix it, replace the distributor (opti) too ;^)
Nab
Related Threads
Chevy Impala SS Forum
1.9M posts
42.7K members
Since 2000
