No spark - BINGO. You have an ignition problem not a fuel problem if it holds 40 psi.
Start by replacing the coil and ignition module (ICM) as they are easiest.
If problem persists, replace the distributor (opti).
This is just a continuation of the same issue(s) from your other thread. IDGet it. The history and continuity there can only help chase down your problem. If you're asking for just electrical suggestions here, then without going back to that other thread it'll be important to know what electrical diagnosis you've tried so far. As mentioned above the IC, ICM and opti (and grounds) are instant targets.
No visual signs of the opti being bad. Just didnt work. Put a new one on and it worked. Changed the harness at the same time too. But the old harness looked fine though.
Aaaaaannd made sure BOTH body seals are actually included - and installed carefully. Even better with some di-electric grease or pool silicone.
Aaaaand there was an issue with thin flimsey caps getting sucked in if a clogged vent, and then grinding the rotor off.
Related Threads
Chevy Impala SS Forum
1.9M posts
42.7K members
Since 2000
