Changing spark plug wires - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 07-11-2019, 04:10 PM Thread Starter
96Lt1civi's Avatar
Hello! How do I go about changing the passenger side spark plug wires? Is there a better way of going about it than removing a bunch of stuff on the front of the engine?
96 Caprice B4U 263k mostly stock
96Lt1civi is offline
post #2 of 11 (permalink) Old 07-11-2019, 04:21 PM
170 hits in just the Engine Problems/Maint. section using the title of your thread. Start here and check another couple promising titles and get back with any remaining questions:
https://www.impalassforum.com/vBulle...placement.html
Free Hint: Most guys replace plugs/wires when doing a regular opti tune-up when it's out and more room to fish the wires through the hole in the access. bracket. At 263k when's the last time you pulled maint. on the opti?
post #3 of 11 (permalink) Old 07-11-2019, 05:19 PM Thread Starter
96Lt1civi's Avatar
Thanks! I bought the car somewhat recently, so I have no idea when the opti was serviced last.
I'm thinking it might be a good idea to take the Opti off anyways and inspect it.
post #4 of 11 (permalink) Old 07-11-2019, 05:50 PM
Dumping the smog pump and all the stuff like the cross over (cross under!) pipe will help.
grandpas wagon
grandpas wagon is offline
post #5 of 11 (permalink) Old 07-11-2019, 06:27 PM Thread Starter
96Lt1civi's Avatar
I deleted the smog pump not to long ago, but I haven't removed the pipe yet.
post #6 of 11 (permalink) Old 07-11-2019, 07:25 PM
It's been a long time since I did mine but IRRC the pipe is a severe impediment on the pass side especially.
There is a bolt by or under the alternator or PS pump that must be removed - a PITA to reach.
Cut the pipe first.
grandpas wagon
post #7 of 11 (permalink) Old 07-11-2019, 07:44 PM
If your pump/tube is removed and using stock length wires, you should do something to secure the driver side wires so they don't flop around. Believe the pump tube has a bracket on it that supports the wires on that side.
This may help and give you some ideas and things to consider. I just made up a little bracket and mounted it to the Block to secure the driver side wires. Everything else is pretty much routed stock.
https://www.impalassforum.com/vBulle...-parts-gm.html
post #8 of 11 (permalink) Old 07-13-2019, 01:13 PM Thread Starter
96Lt1civi's Avatar
Nice write up! Thanks for the help!
post #9 of 11 (permalink) Old 07-13-2019, 01:33 PM
OP
while these cars are not the most convenient cars to swap plug wires on, IMHO there is really no big deal
I encourage you to use all the stock clips & brackets to secure them
I do both sides from under the car. The PS I find it easier to remove the starter and PS tire. Use a screw driver through wheel well to unclip the wire hold downs. Fish the new wire from the front of the car/motor around block. There is a small bolt holding on the metal bracket for #6&8 if you want to remove it to install but I just pop the clip lose and run the new wires in the wire clip
The DS I just remove the bracket holding all 4 wires and re-assemble on bench and feed wires around front of block using the stock 4 wire clip to hold them
If putting on new split loom, use grey stripe. You can order it online for around $15 for 100'. The plastic crap sold at auto part stores will instantly melt. Grey stripe is heat resistant
Name:	plug wires.jpg
Name:	plug wire 4.jpg
Name:	plug wire 5.jpg
post #10 of 11 (permalink) Old Today, 09:49 AM
Sophomore Member
Where's a good place to get the high-temp loom from, and what size did you use?
sherlock9c1 is offline
