Ol' IronBlock LT1 Car Contingency Kit - Chevy Impala SS Forum
 2Likes
post #1 of 15 (permalink) Old 08-06-2019, 05:18 PM Thread Starter
Awfully close to the 10th anniversary of our Great Data Loss, by the way.
If, for some egregiously idiotic reason, the unthinkable happened AGAIN …
What have we learned? By which I mean, what are the most often recurring B- or D- car specific issues, based on our collective experience? Which leads me to …
1. What should we keep handy in our glovebox, clutter catcher, trunk [etc], in case we can't access the ISSF? (Yes, for Camaros, FireBirds, & Corvettes too.)
For example, I carry:
a spare pcm [that I probably don't need]
an idle air control motor & throttle position sensor
a complete ignition kit - Opti-Spark, Opti-wiring, Opti-snorkel, sparkwires & sparkplugs, coil & coilwire, driver module
a fuel pressure tester
a fuel filter & a[n adjustable] fuel pressure regulator
a spare waterpump spline key
coolant reservoir cap
a 4L60E glovebox guide
2. [If not in the car itself,] What should we keep at home [besides an OBD1 ALDL cable & a laptop with TunerPro & $EEhack]?
Originally Posted by 96 Black View Post
Oops! Just caught your meaning. I missed the boat with B-/D- specific pieces. I honestly don't keep too many car-specific things in the car, and stock more things for the kinda trouble "any and every car on the road" gets into. If I think of a pm item with even a hint of messing with my piece of mind out in public, then it's done ordered and in the garage waiting for a sunny to install. And then the takeoff kept as backup. It's sounds like the approach ZO- uses.
Another way of looking at it, is, I am being myopic by being too specific.
I don't like the idea of either waiting for parts, or settling for whatever parts happen to be available.
So far, I see nothing but good ideas. Keep 'em coming, everybody; thanks.
edit: If the stuff that belongs in every car, happens to be in the trunk of a Custom Cruiser / Caprice / Roadmaster /Fleetwood, that can only be good, so please continue to expound on ANYTHING that belongs in the car, whether it's a radiator fan motor, or an MRE.
nickss96 likes this.
They are NOT Lying to You
You are Not Lying to Yourself
Alone (aka The Last Psychiatrist)
Marky Dissod is offline
post #2 of 15 (permalink) Old 08-06-2019, 05:36 PM
[Marky-]Awfully close to the 10th anniversary of our Great Data Loss, by the way.
big ass flashlight
pen and paper
AAA card (another one in my wallet)
insurance card, owners booklet, diag. codes (in the Cady)
gum
charger
TRUNK:
4 thick blankets (for an accident)
3 umbrellas
jumpers
doctors bag of tools
1st Aid Kit
10 bungees
sm. plastic can of gas
via Imgflip Meme Generator
post #3 of 15 (permalink) Old 08-07-2019, 02:05 PM
I carry things that I can change on the side of the road to get me home. The rest I can deal with after a tow if needed.
  • Fire extinguisher and small first-aid kit (in every car!)
  • Ignition coil
  • A piece of solid copper wire (ie: to hang aforementioned coil under the hood)
  • ICM
  • Longest spare spark plug wire I can find
  • Coil wire
  • Serpentine belt
  • Belt tensioner
  • Radiator/Coolant tank cap
  • Fuel cap
  • Upper and/or lower radiator hose
  • Random pieces of hose and wire
  • A bag of various bulbs (headlight 9004, taillight 2057, 194, etc)
  • Basic tool set
  • 1/2 drive ratchet with extension and lug socket, much easier to change a tire with a ratchet
  • Tire pressure gauge
  • Fluids (coolant, oil, trans, ps)
Most of those parts are spares, "good or marginal" removed parts changed during regular maintenance. For example, I wouldn't buy a new spark plug wire set just to carry a spare wire. I just used the longest one from an old used set, works for bypassing a known bad wire in a pinch.
Most of that basically fits into a "milk crate" that I can transfer from vehicle to vehicle.
-- Tom
2011 Caprice PPV
1995 Impala SS
1994 Caprice 9C1 LT1
1995 Caprice 9C1 LT1
1995 Caprice Wagon
1972 Chrysler Newport 2-door
1969 C30 Flatbed
1969 Dodge Charger
storm9c1 is offline
post #4 of 15 (permalink) Old 08-07-2019, 03:00 PM
Z09B4U's Avatar
  • Serpentine belt
  • Belt tensioner
  • Fuel cap
I consider these regular maintenance items and have never had them fail on road. Why do emergency fixing when a new part every five years prevents it? Change them with the coolant. For a car that is in town ten years on a hose is still a good gamble. If I was off roading a old vehicle hoses and belts would be worth it.
Rubber and leather gloves and two small 2X4s to stabilize a jack on dirt are good general kit. LED dynamo flashlight that works every time is good.
I use to do 60-80K miles a year on a company truck. My boss ignored company policy and dealer recommendations. $3000 in tow charges in three years. When I did the same mileage on 20 year old vehicles my only tows in three years were for front wheel bearings (my fault), a voltage regulator went bad and damaged a ignition module, and a snapped axle shaft. New fluids and proactive replacements of wear items are way cheaper than on the road repairs.
+1 on the LT1 specific ignition parts. It can take days to get replacements when you are 300mi from the nearest warehouse.
Z09B4U
Z09B4U is offline
post #5 of 15 (permalink) Old 08-07-2019, 04:46 PM
In complete agreement with you, those things belong in ANY car.
post #6 of 15 (permalink) Old 08-07-2019, 06:16 PM
gbhs72's Avatar
If you live in Oklahoma or Kansas you should always have toll change. If you live in New York you can always wash a few windshields for tunnel change.
Mark: snowman-33
gbhs72 is offline
post #7 of 15 (permalink) Old 08-07-2019, 06:18 PM
Z09B4U's Avatar
I can get parts from the USA in two days to a week. Or at wholesale price here two times the USA price if stocked.
Everything
96Black
See Picture.
Z09B4U
Z09B4U is offline
post #8 of 15 (permalink) Old 08-08-2019, 02:58 PM
Originally Posted by Z09B4U View Post
  • Serpentine belt
  • Belt tensioner
  • Fuel cap
I generally agree. But I learned to carry these things because I've been driving for a long time and I've had all of those items fail prematurely. For example, on one car, a belt fried when the A/C compressor suddenly locked up. Once I unplugged the clutch and installed a new belt, I was back on the road. The failure almost wiped out the tensioner too since it was so violent. It definitely needed changed once I got home since the housing had a small crack. Since then, I liked carrying the tensioner too, and on most RWD cars (which is all I own) are easy to change.
I've had radiator caps fail after 1 week. In fact, I've had them fail out of the box and not hold pressure on the first drive.
And while I've never done it, I've watched people leave gas caps on their trunk or at the station and leave. So in case I ever have that brain fart, I have a spare cap, which on older rear-fill cars, can save you quite a bit of spillage if the tank is full, or on ODBII cars, can save you a CEL.
Likewise, radiator hoses are a crap shoot. I've had them last forever (green hoses) or after a year (black hoses) on a hot day sitting in rush hour traffic.
Carrying spare parts is no excuse for neglecting regular maintenance indeed. But regular maintenance is no excuse for not being prepared for the worse-case scenario, especially since all of the parts in my list are generally lightweight and fit into a milk crate. Stuff happens man. I like to be prepared... and rather than wait 1-3 hours for a tow, I like the option to fix simple things and get going again in a matter of minutes.
-- Tom
2011 Caprice PPV
1995 Impala SS
1995 Caprice Wagon
1969 C30 Flatbed
1969 Dodge Charger
storm9c1 is offline
post #9 of 15 (permalink) Old 08-08-2019, 07:19 PM
You should also have a rotating supply of water for really hot days. Dehydration can happen on less than an hour.
post #10 of 15 (permalink) Old 08-13-2019, 10:18 AM
Scuba Steve's Avatar
Plastic "T" fitting and flow restrictor for the coolant system would be good items to keep on the shelf.
I kept spare fuses and some vacuum caps in my glove compartment
1996 Impala - 190,000 miles - 1/4 mile: 14.94
2008 Grand Marquis - 1/4 mile: 16.26
Scuba Steve is offline
