Lt1 Misfire and running very poorly - Chevy Impala SS Forum
 3Likes
post #1 of 50 (permalink) Old 08-07-2019, 09:39 PM Thread Starter
Mendonmafia's Avatar
My LT1 is suddenly running awful after getting my AC recharged. I also just cleaned and oiled my air filter, and did the oil filter adapter seals but even with the ac off it still runs like garbage so im ruling the AC out. The adapter seals also makes no sense to cause a mis. I did spray all around the engine with brake cleaner last night to clean up the mess I made with AC compressor oil/dye. Maybe I ruined something by doing this? It was mostly on the passenger side though and the driver side its where the misfire is.
Here are some videos of the idle:
https://youtu.be/gjPnAf16ad0
https://youtu.be/IBtzNt5NF70
Seems to only be on the driver side. Exhaust sputters and is not smooth. The exhaust is also dark and smokey on driver side. Strangely if I unplug one of the driver side spark plug wires I don't notice any change in idle. I tried all 4 on the driver side with the same result for each one, no noticeable change in idle.
Today on the way to get my AC system charged it seemed to run fine. It wasnt until about halfway home that it started to act up. Im hoping its the oxygen sensor connection since I had an issue with this after the filter adapter swap. Also the knock sensor wiring somehow became stripped, so hopefully it's just shorting on something? I noticed this after I removed that metallic like tape during the oil filter adapter gasket swap since it was all about peeled off anyways and totally soaked in oil.
The check engine light is off for now.
At idle the driver side exhaust has a periodic (but not on a perfect cycle) sputter as seen in the videos. Under throttle in park it sounds normalish. Under heavy throttle in gear it nearly bogs out and has awful acceleration and sounds terrible. Under light throttle its a total dog, sputters pretty bad, and bogs and I can feel some surging.
Before I did the AC, oil filter adapter, and air filter, I recently (<500 miles) replaced the opti, I was getting code 36 and 42, which vanished after the opti swap. I used a cheapo amazon unit with 3 year warranty. Maybe it's dieing? It is super hot (nearly 100 F) today. I installed an MSD cap and rotor and applied RTV to all the seams and blue locktite to everything. I also did the opti and water pump seals in the timing cover, water pump, plugs, and wires at the same time. I used 10.5mm Busidin silicone wires off amazon and double platinum bosch plugs. It was running great after these repairs/swaps.
Any ideas?
Thanks, Mark
Richland, WA. Moving to Cocoa Beach, FL by November 2019
1994 9C1, 18x,xxx miles
shorty headers, cat delete, CAI, TB air foil, MSD cap and rotor, air pump delete, bosh double platinum plugs
2" front belltech drop spindles, 3" rear drop coils, rear airlift 1000
Cadillac Deville heated leather seats
looking for blue door panels with power window switches, upper and lower dash without holes, power window components and harness, and cruise control components and harness.
Mendonmafia is offline
post #2 of 50 (permalink) Old 08-08-2019, 09:14 AM
angelo's Avatar
Hi, sorry to hear all the trouble with your maintenancce work.
If you search you will see for some reason these LT1's don't like Bosh stuff too much, like plugs and O2 sensors. So you are rolling the dice there.
Also the B-body MAF is sensitive and oiling the air filter is tricky as when you suck in air some oil can get on MAF and make it very unhappy. Rolling the dice again unless you are aware of this and were not generous with the oil.
Keep in mind PCM sees 2 4bangers and not one V8 so that may help you track down the issue. May want to check PCM for codes as not all will turn the CEL on.
When you pulled each plug wire on DR side while car running you saw spark on the end ?
I'll go check the vids now.
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #3 of 50 (permalink) Old 08-08-2019, 09:40 AM
jayoldschool's Avatar
There is a a chance your fresh air filter oil has contaminated the MAF. Remove the filter, clean the sensor in the MAF. Don't touch it, use the correct CRC spray. No brake cleaner! Once clean, reinstall, make sure facing the right way, and start it without the filter. See if there is an improvement.
KingsKrew likes this.
jayoldschool is offline
post #4 of 50 (permalink) Old 08-08-2019, 10:23 AM
Boy, did you and this OP both go out recently and kick a puppy? lol
https://www.impalassforum.com/vBulle...ont-start.html
You both got dam near identical grief right now, even down to the aforementioned likely infamous "too much filter oil got on the MAF" thing. I hope Head- sees this to make sure his is cleaned and the sensor is installed in the correct direction. Regrettably all too often I've found the work I just done did is the (at least round-about) cause of a current gremlin.
This is especially not limited to work you've done. The part about "...suddenly running awful after getting my AC recharged." Cause, correlation or coincidence. :: squinty eyes ::
post #5 of 50 (permalink) Old 08-08-2019, 10:55 AM
On Amazon I see the red can and silver can (more than 3x the cost). Which one are you supposed to use for LT1?
ace72ace is offline
post #6 of 50 (permalink) Old 08-08-2019, 11:35 AM
Red = $4, silver = $7. I never heard of silver before and just use red. The point is steer away from old school 'carb cleaner', brake cleaner, Spray 9, engine greaser or anything else.
post #7 of 50 (permalink) Old 08-09-2019, 12:18 AM Thread Starter
-ALF out...
Thank you for the reply!
Perhaps its the bosch plugs. Doesn't seem to be one cylinder though but maybe it is. I also didn't pull them while the engine was running and it was very sunny so I couldn't see any sparks.
I was rather generous with the air filter oil but wouldn't a dirty MAF sensor cause all the cylinders to miss, not just the driver side?
I bought a cheap $20 code reader on amazon but i either have no codes or it doesn't work. The CEL light does not flash but the fans do come on when i plug in the device and turn the key on (not stating the engine). The ABS feature did seem to work and code 12 was coming up but lets not worry about that for now. This is the reader I used but will be returning it.
INNOVA 3123 GM OBD1 Code Reader https://www.amazon.com/dp/B000EVU8C0..._8aqtDbXWSFKQG
Thanks for the reply!
When i got the car the MAF sensor doohickeys were all totally covered in dirt or something. I cleaned them with a brush and it seemed to make no difference as the car was running fine before despite the dirt. I will get correct spray and try cleaning it but i dont see how only the driver side would be affected by a dirty MAF sensor.
Thank you for this thread! Some how I didn't find this in my search. Seems i cant get the forum search to work well for me but google did return some useful results. Unfortunately it doesn't seem he ever figured out the solution &#x1f615; and so far my car has not failed to start since this issue arose.
As for cause, correlation, or conicidence. Seems like conicidence to me except maybe I fried something with the brake cleaner, the O2 sensor is not connected properly, or the knock sensor wire being nearly bare is causing an issue. Could be the MAF or plugs but I suspect the MAF sensor would cause both banks to mis, and the plugs are supposed to be good plugs but this doesn't mean anything, just my intuition. My headers make pulling the plugs a bitch for cylniders 5-8 so I hope its not these ones lol
post #8 of 50 (permalink) Old 08-09-2019, 08:56 AM
angelo's Avatar
Hi, AFA testing your code reader it is easy enough to unplug the sensor on the Water pump, or the MAF and start the car. That should make CEL go on and you can use reader to get the codes. Then turn car off, plug stuff in, start car and use reader to clear codes and turn CEL off.
That should give you a baseline with the reader working or not.
the reviews on that reader leave a lot to be desired, but if the pins are not sliding into the plastic case you may have a good one. Good Luck.
You can also use a DVM to test resistance on your new wires to be sure they are not defective to rule them out as a problem.
-ALF out...
angelo is offline
post #9 of 50 (permalink) Old 08-09-2019, 11:11 PM Thread Starter
-ALF out...
Thanks for the suggestions!
I started the car with the temp sensor unplugged. CEL came on. Shut car off, plugged in code reader, turned car on (manual says to not run the engine to read codes), no codes so I guess it doesn't work... the reader is essentially a selectable jumper that shorts the proper pins to check engine or abs codes by flashing the respective light on the dash. I didn't realize it was this style until I bought it but I read that jumpers dont work to read codes on these cars.
Before installing the new wires I tested them all and they were about 400 ohms if I can remember correctly.
Anyways the car is running fine now. I cleaned the MAF with electrical contact spray. No noticeable grime or oil was on it or came off during spraying. I also disconnected the DS O2 sensor and sprayed the contacts and reconnected it. I also zip tied the O2 sensor cables to the oil cooler lines to keep them away from the header and I separated the wires near the connector as they are also missing missing insulation near the connector and were too close for comfort. Not sure if any of this helped or not. The day the issue started I also added a can of gumout with PEA (in the can like seafoam comes in) to the gas tank. Maybe my injectors are clogging and the gumout is cleaning them? Idk but the car just ran great for about 15 minutes or so.
post #10 of 50 (permalink) Old 08-11-2019, 10:02 AM Thread Starter
Well my gremlin is back. Went for a longer drive last night and it started to run really bad after about 20 min.
Still only on the driver side. Seems to happen only when fully warmed. which makes me think it's a bad opti. I read that the cheap sensors can fail at high temp. But I'm not sure why it would only effect the driver side
CEL came on briefly but the engine started to run good for about 2 second and then the light went off and it was missing again.
According to this thread:
https://ls1tech.com/forums/lt1-lt4-m...when-warm.html
it seems like it's not the O2 sensor since mine still runs bad at WOT and the issue doesn't start as soon as it goes into closed loop.
I'm totally perplexed. Gonna have to get a real scanner I suppose. Can anyone recommend a good one that's not super expensive? Preferably one that will do OBD 1 and 2.
