Starter covered with oil. - Chevy Impala SS Forum
 1Likes
post #1 of 11 (permalink) Old 09-04-2019, 09:52 PM Thread Starter
HUF
HUF's Avatar
Recently noticed my starter was covered with oil. No oil on the ground. Any known engine leaks in that area?
There’s nothing as permanent as a temporary solution.
1995 Cadillac Fleetwood Brougham 126,XXX miles.
HUF is offline
post #2 of 11 (permalink) Old 09-05-2019, 06:18 AM
Highest-lowest probability = Intake china wall. Valve cover. Breather tube grommet. Oil fill tube grommet. Main seal.
Make sure it ain't tranny fluid?
96 Black is online now
post #3 of 11 (permalink) Old 09-05-2019, 10:25 AM
Dip stick tube grommet? it is right at the starter.
Ken
Ken Hennessy is offline
post #4 of 11 (permalink) Old 09-05-2019, 10:29 AM Thread Starter
HUF
HUF's Avatar
Thank you, gents. Valve cover and dipstick are my primary suspects. Will check them out.
HUF is offline
post #5 of 11 (permalink) Old 09-05-2019, 01:28 PM
if it is the dip stick tube, clean the area and use some RTV. Permatex Black Ultra
post #6 of 11 (permalink) Old 09-05-2019, 01:53 PM
Blue Wail's Avatar
There's no grommet on the dipstick and unlikely to leak even if no silicone was used.
Valve cover is most likely.
Nab
Blue Wail is offline
post #7 of 11 (permalink) Old 09-05-2019, 01:59 PM Thread Starter
HUF
HUF's Avatar
Nab
The dipstick tube was bent a bit when I was trying to approach an oxygen sensor from the top last year, but the area looks dry. The both valve covers are covered with oil and do leak from the seals. Will torque them up a bit and hope
it does not screw up the starter. The starter and especially the solenoid are covered with oil badly. Just another headache for me as if if the brake and charging systems were not enough! )))
HUF is offline
post #8 of 11 (permalink) Old 09-05-2019, 11:46 PM
Tightening up the valve covers will do more harm than good.
Replacement of gaskets is needed.
OEM or Felpro.
KW Baraka likes this.
grandpas wagon
grandpas wagon is offline
post #9 of 11 (permalink) Old 09-06-2019, 06:12 PM
GM 12551633 is the 1994 LT1 dipstick tube part number and the description says including seal
I used an o-ring from ACE Hardware.
post #10 of 11 (permalink) Old 09-06-2019, 07:24 PM Thread Starter
HUF
HUF's Avatar
OEM or Felpro.
Thanks!
HUF is offline
