ABITS Training & Diagnostics Hardcopy Document - Published online - Page 3 - Chevy Impala SS Forum
 1Likes
post #21 of 23 (permalink) Old 02-07-2018, 08:50 AM Thread Starter
juniorwatson's Avatar
Originally Posted by 96 Black View Post
I used angelo's link and picked it up easy. Thanks Steve (junior-)
No sweat, I'll have to look into fixing the document's link. Just a bit busy in and out of work recently and for the next 2 weeks or so.
juniorwatson is online now
post #22 of 23 (permalink) Old 09-20-2018, 10:39 AM
Another link to the PDF, in case Angelo's ever goes away:
http://thefleshrocket.com/images/car...ment-REV-B.pdf
--'94 Caprice "SS" wagon, 0.30 over, high-volume oil pump, LT4 hot cam, 1.6:1 rockers, ported aluminum Corvette heads, shorty headers, PCM4Less tune, 4.10s, shift kit, side-exit dual exhaust with Flowmasters, OR X-pipe, F-body gauge cluster, Bonneville front and rear seats (working electrics), Bravada console shifter, Bilsteins, 12.7:1 Impala steering box, Boss 338s with 255/45R20s, bunch of other stuff I'm forgetting.
--'04 Mustang Cobra, '15 Audi S4
--1125R, 1050, VMax, VFR800, DRZ-400E
TheFleshRocket is offline
post #23 of 23 (permalink) Old 06-13-2019, 03:52 PM Thread Starter
As a final note on this document, I have used the link Angelo created, and used that as "My Homepage" listed under my account name profile.
So you can get to the document this way as well (Left-Click on juniorwatson name, and then select "Visit juniorwatson's homepage")
If there was a way, I'd add it to my SIG, but I've got that filled with my mods.
